Polk PSW1000 vs Velodyne SPL-800R or SPL-1000R?
aat
aat Posts: 45
Hi Guys,
Would you buy Velodyne SPL-800R or SPL-1000R over Polk PSW1000?
Thanks in advance,
AAT
Post edited by aat on
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    I had a velo spl 1000 series 2 not r...Only difference...no eq on mine. Very happy with it. sold it to a friend and he is as delighted as I was. I am not familiar with the polk.
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • cmy330go
    cmy330go Posts: 2,341
    edited January 2007
    I have the PSW-1000, and as much as I love Polk Audio......buy the Velo.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Depending on what you like....a lot of bass or sq you might look to the spl 12 or even the brand SVS. Everyone here will at least agree on that if nothing else!
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • pblanc
    pblanc Posts: 261
    edited January 2007
    I recently bought a Velo SPL 800 series II used. I've had some issues with the amp turning on in response to an input signal. When it works it has amazing punch for its very compact size. I use it in a small room, pretty much for music listening only, to give some bottom to a high quality pair of monitors. If using it for home theater or in a larger room, the SPL 1000 would probably be better.
  • aat
    aat Posts: 45
    edited January 2007
    Thanks for your quick responses so far.
    I'm going to use the sub more for mine home theater. My budget is between the PSW1000 and Velodyne SPL-800R (maybe stretch to SPL-1000R).
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2007
    SVS=more sub less money
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Do you have a y connector? If not this should resolve any issue with the auto on problem!
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • mantis
    mantis Posts: 17,563
    edited January 2007
    The Velodyne SPL series is superior to all the polk subs. I like Polk 2 but Veloydyne does a much better job.
    There DD series is very good, tricky to get setup to sound good with music but with lots of time and efford, it can be done.
    Dan
    Dan
  • pblanc
    pblanc Posts: 261
    edited January 2007
    I am actually running a pair of stereo interconnects from a passive preamp to the line level L/R inputs of the sub, then a pair of interconnects from the line level outputs of the sub back to an amp.
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    How long of a run..and with what brand of interconnect?
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    If for home theater go bigger... then you will have no regrets...you can alway turn it down...only so far you can turn it up!
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Pepi28
    Pepi28 Posts: 248
    edited January 2007
    For the price of the velo you can get an svs pb12/2. Hits harder, lower and louder for about the same dough.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
