Differences between Monitor 5Jr & 5Jr+
shoester5
I have a pair of Polk Audio Monitor 5Jr+s that Ive had for some time and after scanning eBay for bargains, I came across a single 5Jr that I thought Id buy for spare parts. Well, I received the speaker today and needless to say, it was damaged in shipping. Luckily, It was well packed and the despite the abusive handling, the cabinet made it unscathed. But, as I was unpacking it, I noticed something rolling around inside the cabinet. After taking the passive radiator out of the cabinet, I discovered that FedEx had thrown this package so hard they knocked the coil off the crossover. Upon removal of the crossover, in order to repair it, I found a label which stated it was a crossover for a 5Jr+ but the label on the back of the cabinet states its a 5Jr. Now, my question is this. What is the difference between the 5Jr and the 5Jr+? Also, why did Polk use a 5Jr+ crossover in a 5Jr? I can see no difference between my original pair of 5Jr+s and the single 5Jr I got from eBay.
shoester5
_________________
fronts: SDA SRS 2.3TL
rears: SDA 2B
center: CS 400
sub: M & K MX90
Carver CT29V
Carver TLM-3600
Carver TFM-35X
2-Carver TFM-15CB
Carver TFM-6CB
Denon DP51F
DBX 3BX
AudioControl C-101
_________________
rears: SDA 2B
center: CS 400
sub: M & K MX90
Carver CT29V
Carver TLM-3600
Carver TFM-35X
2-Carver TFM-15CB
Carver TFM-6CB
Denon DP51F
DBX 3BX
AudioControl C-101
Post edited by shoester5 on
They were smoking lots of Dope then.
http://www.polkaudio.com/forums/showthread.php?t=38755
The crossovers seam almost identical. The woofers were MW6502's in all M5's, and the tweets were changed around a bit. If its just your crossover that broke just resolder the inductor back on.
Ben -
I have a pr. of full size 5s (larger passive radiator). The only thing on the crossover is the year 1987. It has the MW6502 woofers and SL2000 tweets. It's too bad about shipping damage. UPS is usually the destroyer for me. Let me know what yr yours are and would drivers you have....
Smoking dope back then?? Darn I missed another good job! .... I remember that promoting prize. 1 lucky new owner finds a nickel bag in his speaker....
According to the schematics, the only differences I can see is Polk went to a 13.5uF capacitor instead of a 12uF when they updated the tweeter from the SL2000 to the SL2500. Both the 5Jr and the 5Jr+ that I own, have the SL2500 tweeter. I’m assuming the difference between the two speakers is the tweeter, but they put the SL2500 in both speakers I own. I’m still confused. Could it be that the speaker is labeled wrong?
Ben, the crossover has already been repaired and sounds great. I soldered the leads of the inductor to the board and just taped it in place. Thanks for the link to the schematics.shoester5
_________________
rears: SDA 2B
center: CS 400
sub: M & K MX90
Carver CT29V
Carver TLM-3600
Carver TFM-35X
2-Carver TFM-15CB
Carver TFM-6CB
Denon DP51F
DBX 3BX
AudioControl C-101 -
I also own a pair of the bigger size Monitor 5b’s with the larger passive woofer. It features a MW6502 woofer and a SL2000 tweeter with a date of 1987 on the crossover. Both of my 5Jr’s have the MW6502 woofer and the SL2500 tweeters and both are marked 5Jr+ and 1990 on the crossover.shoester5
_________________
rears: SDA 2B
center: CS 400
sub: M & K MX90
Carver CT29V
Carver TLM-3600
Carver TFM-35X
2-Carver TFM-15CB
Carver TFM-6CB
Denon DP51F
DBX 3BX
Unfortunately, I didn’t find any surprises inside the cabinets!shoester5
_________________
rears: SDA 2B
center: CS 400
sub: M & K MX90
Carver CT29V
Carver TLM-3600
Carver TFM-35X
2-Carver TFM-15CB
Carver TFM-6CB
Denon DP51F
DBX 3BX
Crispycircuit wrote:Smoking dope back then?? Darn I missed another good job! .... I remember that promoting prize. 1 lucky new owner finds a nickel bag in his speaker....
LMAO... Agreed! -
