Harman Kardon AVR445 or Denon AVR-2307?
mKvDuBBy
mKvDuBBy Posts: 34
Wich one would you choose for running RTi10's, FXi5's, CSi5, PSW505. Or any other suggestions. Thanks in advance. :D
Post edited by mKvDuBBy on
  • danger boy
    danger boy Posts: 15,722
    edited January 2007
    Denon
    PolkFest 2012, who's going>?
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    danger boy wrote:
    Denon
    any particular reason?
  • danger boy
    edited January 2007
    just because...
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    danger boy wrote:
    just because...
    NICE. :confused:
  • danger boy
    edited January 2007
    mKvDuBBy wrote:
    NICE. :confused:
    You're welcome. you're very nice too. ;):D Can I have a hug? :p
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    YaY I have a new friend. Thanks for reals though. Its still a toss up for me. Im kind of leaning towards the HK though. i dont know why but I am. :D
  • Ricardo
    Ricardo Posts: 10,634
    edited January 2007
    I'd go with the Denon, for the same reason as DB...
    I've had my 3803 for 2 years and there's nothing I don't like about it.
    SOPA
  • george daniel
    george daniel Posts: 12,096
    edited January 2007
    I think in the long run that you will be happier with the Denon,,just my .02 worth
  • ben62670
    ben62670 Posts: 15,969
    edited January 2007
    Does the Denon have pre outs?
    One thing I love about my HK is the pre out setup. One thing I hate is the remote.
    check out this thread, its almost the same topic as yours.
    http://www.polkaudio.com/forums/showthread.php?t=47295
    Enjoy Ben
    Ben
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    Enjoy Ben
    I dont think that the Denon does that is why I am leaning towards the HK. Honestly I dont even know what the pre outs are used for. Can anyone help me out sorry. :confused:
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited January 2007
    Pre outs provide unamplified output as opposed to the amplified output that goes to the speakers ...
    This allows use of a separate amplifier which would reduce a receivers usage to that of a pre amp or pre/pro.
    This has benefits in the upgrade process as it allows first adding an amp and later replacing the receiver with a pre amp as opposed to having to get both a pre amp and an amp simultaneously in order to replace the receiver.
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    I got it. Thanks. . . Yeh I think I have made my decision. Does anyone have any suggestions on an amp for running the RTi10's. I wont be able to buy the amp now but sometime in the future.
  • PolkWannabie
    edited January 2007
    There are a zillion choices ...
    Start with a budget ( Dollar Amount ) ... Do yourself a favor and think USED ... and start looking around on places like Audiogon to see what can be had at the price point you are looking at and then research those ...
    If you made a face when I said used then consider the fact that gear like amps can be bought relatively inexpense compared to new prices and will be worth the same as what you paid for it for several years ... What this means is that when you have upgraditis later ... The used amp will have cost you something between nothing and very little.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited January 2007
    And you will...:D
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    i did put that into consideration but. I want a receiver with an HDMI input. I have been trying to find some used ones but no luck yet. The cheapest I found the AVR445 is $715.00 do you guys think that is a good price or I can find something better.
  • PolkWannabie
    edited January 2007
    I thought we were talking amps ?
    I'm not sure why you care if the receiver or preamp has HDMI ... To me that's just another component to have to pass a video signal through ...
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    The only reason im going to use the HDMI for is the PS3 and SAMSUNG HD DVD. So what do you recommend I do. Or should I just get a used AVR635 on ebay for much cheaper. Thanks for the information.
  • PolkWannabie
    edited January 2007
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    Personally I hook up video sources direct to the TV ...
    But isnt HDMI video and audio. I dont think I can hook up HDMI and optical at the same time. Is that possible. If it is then I will get the HK AVR635. if not then the AVR445.
  • Ricardo
    edited January 2007
    You can hook up HDMI to your TV and optical/coaxial digital audio to your receiver. The only reason for getting a receiver with HDMI (IMO) would be if you have more HDMI sources than inputs in your TV, and you want the receiver to make the switching.
    SOPA
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    PERFECT. . . I will go ahead and get the AVR635 from Harman's ebay site.
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited January 2007
    I think that the general consensus is that buying an AMP used is a very good idea. You can find good ones on ebay or audiogon for about 1/2 of retail, or even less.
    However, with surround sound receivers, it seems most people always want the latest and greatest in features (such as HDMI), etc.
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
