i think my dvd player died
goingganzo
i get a reeor message everytime i put in a disk and i tryed to clean the dvd player but it dident work. here is my problem would it be cheaper to fix or just throw it out and get a new one with progresave scan ?
i am heading tward geting a new one i figure i can get a good one for around 150-200
toshiba SD4800
toshiba SD3800
Onkyo DV-SP500
toshiba SD4800
toshiba SD3800
Onkyo DV-SP500
Post edited by goingganzo on
bury itDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
I like both the Toshibas that you mentioned or the Panasonic RP62 or RP82. Since I don't have an HDTV I don't need a progressive player. I looked at the Toshiba SD4800 and the Panasonic RP82 because they both do DVD-A and I was interested in that format. I decided to just stay with SACD so ended up not getting either but they are both good players with excellent picture quality."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
What discs are you putting in it? Are you trying CD-R'S and CD-RW'S? Your player might not be compatible.
Explain a little more and maybe we can save it.
If not throw it out. -
well back to my first post, if it is broke - I suggest burrying it.Damn you all, damn you all to hell.......
I promised myself
dvd players are the worst made electronic devices ever
no...the vcr is...ahaDamn you all, damn you all to hell.......
I promised myself
DVD players are only as good as the build quality. Hey a $59 player will not last like one for $1000 or even $600. Do get progressive scan. Some day you will have a TV that will use it. Sony, Pioneer, Toshiba and Panasonic are the manufacturs that I would consicer first.
Ya - these idiots running out to Wal-Mart to buy their after Thanksgiving $48 dvd players. All I can do is smile. Suckers!!!!
aha, I will only spend around 130 dollars min. on a dvd player - 300 dollars max.Damn you all, damn you all to hell.......
I promised myself
it wont play any disc that i put in it dvd or cd this are what i am cosidering now
Harman Kardon DVD 25 250
Onkyo DV-SP500 200
Onkyo DV-SP300 150
toshiba SD4800 180
can any one else recomend a dvd player besides sony that is in my price range anything under 300 -
Crutchfield is having some pretty good sales on DVD players and changers. My sis bought a Kenwood changer from them a few months ago and is happy.
Some players have only a 3/12 warranty.. some are 12/12. I know it isn't a hard and fast rule, but I do find myself feeling a little better about a component if the manufacturer is willing to put a longer warranty than the standard - assuming the manufacturer is reputable, meaning they will actually be around for the warranty period! -
i did it i got the Harman Kardon DVD 25 for 200 have to update the old website and the system showcase
