Newbie Question: What Receiver To Use
mKvDuBBy
mKvDuBBy Posts: 34
I am new to this forum. I have recently bought the Polk RTi10's, FXi5's, CSi5's, PSW505. I dont have a clue on what receiver to use. And I dont know anything about amping speakers. What would I need to make the speakers run to its full potential. Do you think I can get something for under 600 for that or would I have to spend more. Thanks in advance. :D
Post edited by mKvDuBBy on
  • Ricardo
    Ricardo Posts: 10,634
    edited January 2007
    Welcome to the forum; nice set of speakers you have there.
    You can power them with a "high" watt receiver, but the RTi10's will require an external amp if you want to hear their full potential (not a must, but will improve their sound).
    You have several options with that budget, in the used market. You can buy a used Denon that has over 100WPC (I have a 3803 and sounds great with my setup), or buy a lower power receiver with pre-outs and a stereo amp for your RTi10's. This is probably what I would do.
    SOPA
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    what lower power receiver would you use and what amp for the rti10's? Thanks
  • ben62670
    ben62670 Posts: 15,969
    edited January 2007
    http://stores.ebay.com/Harman-Audio
    They have quite an assortment of refurbished items direct from Harman. I purchased mine from there, and so have others here. The one thing I like about the HK's is the pre outs so if you get the bug to upgrade to external amps you have that capability.
    Ben
    Ben
  • Ricardo
    edited January 2007
    HK link above is a god option for receivers; for amp, I'd get a 200 WPC Adcom or similar; look in Audiogon or in the flea market here, or ebay.
    SOPA
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    would the HK AVR 445 run the setup well? I am still looking at an amp to upgrade later on for the the RTi10's but will that do for the meantime to run the system?
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    Please Help I Really Need More Answers. . . Thanks Again.
  • Ricardo
    edited January 2007
    The 445 has 65 watts, which for HK it's good watts; you'll be able to drive your RTi set just fine. You won't be getting all the 10's can give, but it will sound good. If you can get a stereo amp down the road, you'll be set.
    SOPA
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    sorry for all the questions but what amp would you recommend i get in the future?
  • danger boy
    danger boy Posts: 15,722
    edited January 2007
    starting another thread with the same question.. doesn't help you make any friends..
    what is your budget for a recevier? If you don't mind buying used ones.. you can get a better deal. What will your recevier be used for? 20% music and 80% movies? Give us some info before we can recommend more receviers. There are hundreds of receviers out there..
    PolkFest 2012, who's going>?
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    I didnt make another thread for the same question. I stated that I want to spend 600. I already decided on the DENON AVR2307 or the HK445. Thanks for helping out though.
