Adding on another amp
doug lang
doug lang Posts: 261
My main pre is a Sunfire with a Sunfire amp. I just got an aditional amp Nad for surround back speakers. My question is can it be possible for the Nad to turn on when the Sunfires turn on. There are no additional plug in's with the Sunfire pre. And the Sunfire Amp triggers auto on with the pre. I would like all to turn on so i do not have to get up. I am spoiled and lazy. Thanks guys, Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited January 2007
    Does the NAD have a 12v trigger input jack on it ?
    If so the Sunfire can be used to trigger it.
  • doug lang
    edited January 2007
    No 12v trigger input. I thought i saw some kind of devise here for this purpose.
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2007
    Just leave it on all the time.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2007
    Yeah. It won't hurt it just to leave it on.That's what I do with my Outlaws.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • PolkWannabie
    edited January 2007
    You can leave it on all the time ... or ... there are power control/filtering devices that have remotes ...
  • doug lang
    edited January 2007
    Yea i guess i can do that. I remember this question in the past with the same conclusion. I will leave it on.
    Thanks Doug
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • louthewiz
    louthewiz Posts: 581
    edited January 2007
    The device in the link below is designed just for that use , all you do is plug the device into the wall outlet then plug in the preamp into the blue outlet on the strip ,and the amps into the red outlets and when you turn the preamp on the amps turn on, and when you power down the amps turn off just like a 12 volt trigger..
    http://bitsltd.net/ConsumerProducts/buy.htm
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • doug lang
    edited January 2007
    Hey thanks for the link. I knew i saw this before, just could not locate. I will place an order. Thanks again. The very best,Doug
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
