Adding on another amp
doug lang
My main pre is a Sunfire with a Sunfire amp. I just got an aditional amp Nad for surround back speakers. My question is can it be possible for the Nad to turn on when the Sunfires turn on. There are no additional plug in's with the Sunfire pre. And the Sunfire Amp triggers auto on with the pre. I would like all to turn on so i do not have to get up. I am spoiled and lazy. Thanks guys, Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
Does the NAD have a 12v trigger input jack on it ?
If so the Sunfire can be used to trigger it. -
No 12v trigger input. I thought i saw some kind of devise here for this purpose.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
Just leave it on all the time.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Yeah. It won't hurt it just to leave it on.That's what I do with my Outlaws.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
You can leave it on all the time ... or ... there are power control/filtering devices that have remotes ...
Yea i guess i can do that. I remember this question in the past with the same conclusion. I will leave it on.
Thanks DougOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
The device in the link below is designed just for that use , all you do is plug the device into the wall outlet then plug in the preamp into the blue outlet on the strip ,and the amps into the red outlets and when you turn the preamp on the amps turn on, and when you power down the amps turn off just like a 12 volt trigger..
http://bitsltd.net/ConsumerProducts/buy.htmMy gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Hey thanks for the link. I knew i saw this before, just could not locate. I will place an order. Thanks again. The very best,DougOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
