Sub Placement Q
inspire
inspire Posts: 21
placing a sub(PSW404) on the side of the room(left or right) would hurt performance rather than putting it on the corner???
Haven't tried the back side cuz of short wire! :(
Where do u guyz place your SUB?????
L front Center R front
SUB-->
S L :)! S R
S B S B
My Setup
panasonic 50" plasma
Monster Power 7000 SS
Silicon Image IscanUltra Pro
B&K reference 50 preamp
B&K reference 200.7 amp
Martin Logan Ascent i main
Martin Logan Theater i center
Martin Logan Decent Sub
Polk RT 800 for side surrounds
Polk FX300 for Rears
Post edited by inspire on
  • danger boy
    danger boy Posts: 15,722
    edited December 2002
    Left Cent Right
    beer, chips, beer, DVD's
    LS :lol: RS SUB
    PolkFest 2012, who's going>?
  • mantis
    mantis Posts: 17,374
    Placement of a sub,well you gotta move it around a bit.I like to keep it in the front half of the room is possible.The side wall placement should work out fine if you take some time setting it up and getting the correct phase.
    Dan
  • Frank Z
    Frank Z Posts: 5,860
    Corner loading works for most applications. Try placing it in a corner of the longest wall in the room.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    I second Frank - corner placement excites the most possible room modes and minimizes nulls and also gives the most boundary reinforcement and SPL.
    There are exceptions to this general rule, so experiment.
    I violated my own advice and I'm about 1/3 out from a corner along a wall - it's the closest I could come to a corner with my particular set-up.
    Doc
    SVS
  • Apex
    Apex Posts: 69
    What i did was placed my sub right at my listening position (on the floor,not on the couch).Then went around the room and listened for the best results.I then placed down a magazine,(what i had in my hand at the time)and placed it at that point.
    I then placed the sub at that position i placed the magazine.The improvement was substantial,subwoofer placement is very crucial.
    Hope this helps.
    H/K AVR7000
    "LSI25's bi-wired with 2.4s
    Mirage OM c2 Center "LSiC soon"
    FX300i rears "LSi15's soon for the rears".
