Binding posts
joeparaski
It's time to do some upgrades. Question....are speaker binding posts the same as the binding posts behind an amplifier? I find that the banana plugs that go to the connectors behind my Phase Linear amps are loose and don't have a good solid connection. I'd like to replace ALL these posts on my amps, what should I use and is this easy to do (I have little experience with amplifier innards).
Also, my Bose 1801 amplifiers have 1/4 inch jacks in back for the speaker connections. I'd like to replace these with RCA type connectors. Again, is this easy to do for a novice and what type of connectors should I get and where do I get them from?
I would appreciate any advice from the experts out there, thanks.
Joe
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
I like WBT or Vampire.
http://www.partsexpress.com/webpage.cfm?&WebPage_ID=292&CFID=4082790&CFTOKEN=93943034
http://vampirewire.com/mcart/index.cgi?code=3&cat=5HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
