Unwanted Radio coming through Subwoofer
smyoung
smyoung Posts: 2
Hi,
I have this annoying problem where I can hear my local radio
station being picked up through my subwoofer. This occurs
even when I have my amp turned off or set to DVD. The subwoofer is a PSW250 connected via CableTalk Talk 3.1 to a
Yamaha RXV530. The subwoofer is positioned about 2 metres
away from the amp. Does anybody have any suggestions on how I can alleviate this problem?
cheers,
Simon
Post edited by smyoung on
  • mantis
    mantis Posts: 17,505
    edited December 2002
    Sound like your using your interconnect as an antenna.
    Swap out the cable for a higher quality shielded cable.Monster makes em as well as aot of good quality cable companies.You problem allies there I believe my friend
    Dan
  • fireshoes
    fireshoes Posts: 3,167
    Do they have Monster cable in Australia? haha
  • scottvamp
    scottvamp Posts: 3,277
    Not sure what this is - I agree try some good shielded cable.
    Monster Bass Cable.
  • danger boy
    danger boy Posts: 15,722
    In Australia look for IXOS cables.. very similar to monster.. i used to have the same problem with my sub.. when my neighbor would use his ham radio.. got a 3 meter IXOS sub cable.. no more noisey neighbor
    PolkFest 2012, who's going>?
  • mantis
    SO did we cahnge out the cable and now the sub isn't a radio anymore???I 'd like to know.
    Dan
  • smyoung
    smyoung Posts: 2
    Thanks for your replies guys. I did a few experiments to confirm
    if the cable was the culprit and it indeed looks like it.
    - I disconnected the speaker cables from the amp to the subwoofer. Still happening.
    - I disconnected the cables from the subwoofer to the satellite speakers as well. No radio.
    - I then used a different cable to hook up the subwoofer to the amp. This time I just used a Y-cable interconnect from the subwoofer output on the amp to the line inputs on the subwoofer. Could still hear the radio.
    An interesting note. If I turn the subwoofer off via the switch at the back I can still hear the radio through the speaker! It only stops once I pull the power cable out of the power point.
    Looks like my only option is to swap out the speaker cable which I'm not too cool about. I only bought it a couple of weeks ago and it cost me a packet!
    Does speaker cable come shielded? I had a look on the web sites and they don't seem to have much info.
  • ntculenuff
    ntculenuff Posts: 1,146
    almost sounds as if you could use something like the monster power, where it actually cleans up the electrical noise that comes through ???
    just a thought
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
