My tip of the day...
VR3
VR3 Posts: 29,514
edited December 2006 in The Clubhouse
For all those wanting to install a hardwood floor...anywhere...
Work from doorways over, not from over to doorways...
Because when you are working with locking joints, intricate cuts - its just a pain....
Im about to pull my hair out......
But, good news is - once I get this small piece in... it will be relatively smooth sailing...
Scary thing is, I wasnt having such a hard time getting one piece together and had to apply so much force the entire floor moved... with me, a tv, computer, and 8 planks on top of it like nothing... but I got it back in square with a lil more opposing floor...
Ah well, just sharing some wealth of knowledge for those thinking about getting those vinyl, interlocking wood floor planks thingys...
They are easy, until you get into the intricate cuts to where the lifting up locking isnt possible... you gotta pretty much beat the piss out of these things to get them to go together with both are flat...
Post edited by VR3 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    I notch the trim, not the flooring, so only 2 cuts are required to enter the doorway, nothing intricate.
  • Fireman32
    Fireman32 Posts: 4,845
    Trey, I dont start at the doorways. I start at a wall and make sure that i get the first row straight and then when i get to the doorway I do what Dennis said and notch the trim.
    VR3 Posts: 29,514
    I cut out the door frame bottoms..
    But what happens is, its interlocking tounge and groove - and when put in tight spaces, its incredibly hard to "snap together" so to speak...
    Took me about 2 hours to put down 2 whole rows (16" wide, 10.5' long) - which is rediculous, I put down 70% of the room in that time, but no tight spaces...
    I wish I would of started it a bit different...
    The rest will be easier, will do it tommorow... Im beat, I feel sorry for the Amish...
    Im using a hand saw and a jigsaw for this entire project, haha...
  • WilliamM2
    WilliamM2 Posts: 4,808
    I'm with Dennis. We pulled the doors and trim right out, then after flooring, put the doors and trim back on, but we were also installing new trim anyways.
    VR3 Posts: 29,514
    Eh, no way Im pulling the trim and frames out... wow, way to much work.. hehe
    Im just having problems since I am trying to integrate the closet into the same floor, and its involving some intricate cutting... but I got the hard part over with... haha
  • Fireman32
    Being that you have to leave a 1/4 inch gap for expansion you either have to reinstall the trim or put 1/4 inch round trim down to cover the gap.
    VR3 Posts: 29,514
    Im putting the round over trim down...
    But I put the wood under the door frames, which still has a gap - but... it looks good since you cant see the subfloor... thats why its difficult, Im putting the floor under the doors and I cant lift up on the planks to put them together, so I have to slide them together which isnt their exact design by far... hehe
  • Fireman32
    I understand completley Trey. The last row is always a ****. The last floor I did for a friend of mine had some inricate cuts by the doorway and one wall was bowed out. I started the first row at the bowed wall and made alot of cuts on the first row so it was nice and straight. The first row took about 2 hours with all of the measuring that had to be done. The rest of the floor took about the same time. When we got to the last couple of rows we hit a doorway that was on a angle and required some thinking to get everything to fit right. On the last row we had to cut the planks down so we could fit it. Since we were putting down round trim we cut just enough so we can snap it in without to much difficulty and cover the gap with the trim. Hope this helps.
    VR3 Posts: 29,514
    Yeah, thanks for the advice...
    Ive pretty much got everything in my room installed, all I have left is the closet - which will be incredibly easy in comparison...
    Cant wait for it to be done... once I get the molding attached - all I will have to do is do a LIL touch up paint where my hammer marred the trim.... then all will be done - will take pics of the room completely empty... Im very happy with how it looks so far... :)
  • Fireman32
    Glad to hear it bud. Cant wait to see the pics of it.
  • halo
    halo Posts: 5,618
    ^^^ What he said :)
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
  • swchma
    swchma Posts: 49
  • halo
    halo Posts: 5,618
    swchma wrote:
    Wtf?
    WTF is your problem? You start something in a different thread and bail: link
    You trying to start something here too or have you learned your lesson?
  • bobman1235
    bobman1235 Posts: 10,822
    He hasn't learned his lesson, he's a troll, he'll be gone soon.
