Looking under the hood
17810121342
    SCompRacer Posts: 9,121
    edited November 2006
    Marchand XM44 active crossover for my Innersound Eros MKII speakers. The first design Innersound bass amp/active crossover only had one knob to control bass/mids. The XM44 has seperate low and high controls for my bass amp and panel amp, with a 5dB mids boost control in the 5Hz to 2KHz range allowing me unlimited, picky bastage flexibility.
  • AndyGwis
    AndyGwis Posts: 3,655
    I'll be stealing my gf's or 'rents digital camera to post some pics, hopefully of my HK 635, both B&K late 80's gear, and maybe even one of my carver tfm-6cb (love those little guys, so damn versatile).
    All this green I drop on audio gear, and I can't drop $250 on a camera. . . just seems silly.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • speakergeek
    speakergeek Posts: 555
    edited December 2006
  • Systems
    Systems Posts: 14,872
    I like that xm44.Nice neat layout on the PC boards and by the look of it ,it uses stepped attenuators for level control instead of pots which is a nice touch.
    Testing
    Testing
    Testing
  • dorokusai
    dorokusai Posts: 25,576
    CJ PV-7 Tube Pre-Amp....look at that MINT faceplate and guess what year it was manufactured? 1987.
  • beardog03
    beardog03 Posts: 5,550
    Mark,
    very nice piece !
    does she sound as good as she looks ?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • hearingimpared
    hearingimpared Posts: 21,136
    No matter how old or out of style CJ gear is always beautiful.
  • Early B.
    Early B. Posts: 7,900
    Guts of Marsh A200S...
    BTW -- what are those 4 little circular thingys on each side of the chassis?
    "God grooves with tubes."
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    They look like the output transistors, but I don't see the reasoning for having them lay flat without a surface against those huge heatsinks. The heatsinks look like they are serving no purpose in those photos to me. I'm sure I'm missing something.
  • Systems
    Very nice amplifier Early,those circle thingies are the output transistors.
    Testing
    Testing
    Testing
  • Systems
    They are mounted to a metal L bracket which is screwed to the heat sink.You can see white thermal grease around the edges of the L bracket where it attaches to the heat sink which helps heat transfer.
    Testing
    Testing
    Testing
  • Systems
    Zero wrote:
    Early,
    They are mosfets.
    Actually those are bi-polar transistors.Marsh uses fets elsewhere in the gain stages but bipolars for the outputs.
    Testing
    Testing
    Testing
    heiney9 Posts: 25,487
    Bipolars can look like Mosfets when they are in a "can" (the metal encasing). Not all bipolars come in a "can". It just depends on who/how they are manufactured.
  • Early B.
    Zero wrote:
    ...Cool amplifier.. one of the better sounding class A/B amp's I've heard for the price (at least, when ran direct). I hope she sings for you!
    Sounds great so far. Still waiting on my tube pre to arrive. Then we'll see how the Marsh with tube pre stacks up against the Jolida tube int. amp.
  • Systems
    Yes correct I have seen Mosfets and bipolars in TO3 metal can's and both in the now more popular TO3P plastic case.Marsh does use bipolars for his outputs though.
    Testing
    Testing
    Testing
    Agreed
    Zero wrote:
    Early,
    I look forward to reading your impressions.
    Yes, impressions once you have had a chance to break her in.
  • Systems
    Yes I would also like to know your impressions.I bet you will like it a lot.
    It is very nicely put together and designed by a great engineer.
    Testing
    Testing
    Testing
  • Early B.
    I noticed that when powered on, the Marsh has these little red lights (4 pair plus two up front) on the circuit board that light up. Does anyone know what their function is?
    If you take another look at the pics I posted, the lights run horizontal in the middle of the board.
  • Systems
    Sometimes LED's are used in bias circuits instead of regular diodes.Maybe thats the case with this unit?
    Testing
    Testing
    Testing
  • speakergeek
    Did I mention these are some good pics?:D
  • Kahuna
    Kahuna Posts: 35
    dorokusai wrote:
    You guys are lame....imagine re-tubing this to the tune of 22 tubes....
    dorokusai what make is this? (Possibly a BSR ADC B100?)
    mhardy6647 Posts: 35,162
    The ADC B100 had 13 tubes, all 6DJ8's. I (briefly) owned one and posted a photo or two of it earlier in this thread (post #139).
  • Ricardo
    Ricardo Posts: 10,634
    My 350a developed a problem in the last few weeks; the right channel was going on and off; I could fix it by touching/moving the RCA plug; another thing I noticed was that the center (vocals) were all over the place...sometimes to the right, sometimes to the left, sometimes dead center....
    So I decided to get the original RCA jacks (Thanks to Dave Belles who pointed me to the right place to get them) and changed them today; the problem was not the jack itself, but the solder on the board was broken (not sure if it can be seen in the picture..the little connections to the right; the big ones are just to fix the jack to the board).
    Edit: yes, it can be seen if the picture is enlarged to the original resolution)
    Anyway, the problem is fixed and thought I'd share some guts:)
    The toroidal is almost 4" high and diameter is 7"....never seen such a big one
    SOPA
  • dorokusai
    It's a Fisher 400...not exact on the year but its old.
    Good work HTrookie. The broken joint is easy to see in that pic and a common problem in gear. Well, common in that I've seen that as a simple fix for a bunch of gear over the years. That, and fuses.
  • adam2434
    adam2434 Posts: 995
    Picked up a vintage Sansui Eight receiver (circa '73-75) a couple days ago just for the heck of it and to have something to play with (it only cost $35).
    It had some scratchy controls, which I fixed with Deoxit and cycling. Also cleaned the inside of the unit.
    It's been fun to work on a vintage piece from when I was just out of diapers. Maybe my first re-cap job is next. This thing is built well and heavy (almost 40 lbs), has solid aluminum knobs and face, walnut case, and the classic 70's vibe. I've been hanging out a little in the Sansui forum over at audiokarma.org. This old Sansui stuff has quite a following.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Looks nice.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • halo
    halo Posts: 5,618
    Innersound Active Crossover / 600 wpc (Bass) Amplifier with Remote!
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
  • Systems
    Thats a fine lookin piece ,nicely put together .The remote is a nice touch also being able to adjust bass level from the listening chair is a bonus.
    What kind of woofers are you using with the ESL,s?
    Testing
    Testing
    Testing
  • hearingimpared
    Halo wrote:
    Innersound Crossover (Bass) Amplifier with Remote!
    Very pretty stuff Vic.
