Show me your ****(embly), and let me get in your guts baby!
Marchand XM44 active crossover for my Innersound Eros MKII speakers. The first design Innersound bass amp/active crossover only had one knob to control bass/mids. The XM44 has seperate low and high controls for my bass amp and panel amp, with a 5dB mids boost control in the 5Hz to 2KHz range allowing me unlimited, picky bastage flexibility.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
I'll be stealing my gf's or 'rents digital camera to post some pics, hopefully of my HK 635, both B&K late 80's gear, and maybe even one of my carver tfm-6cb (love those little guys, so damn versatile).
All this green I drop on audio gear, and I can't drop $250 on a camera. . . just seems silly.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Good stuff!:)
SCompRacer wrote:Marchand XM44 active crossover for my Innersound Eros MKII speakers. The first design Innersound bass amp/active crossover only had one knob to control bass/mids. The XM44 has seperate low and high controls for my bass amp and panel amp, with a 5dB mids boost control in the 5Hz to 2KHz range allowing me unlimited, picky bastage flexibility.Testing
Testing
Testing -
CJ PV-7 Tube Pre-Amp....look at that MINT faceplate and guess what year it was manufactured? 1987.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Mark,
very nice piece !
does she sound as good as she looks ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
dorokusai wrote:CJ PV-7 Tube Pre-Amp....look at that MINT faceplate and guess what year it was manufactured? 1987.
No matter how old or out of style CJ gear is always beautiful. -
Guts of Marsh A200S...
BTW -- what are those 4 little circular thingys on each side of the chassis?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Early B. wrote:Guts of Marsh A200S...
They look like the output transistors, but I don't see the reasoning for having them lay flat without a surface against those huge heatsinks. The heatsinks look like they are serving no purpose in those photos to me. I'm sure I'm missing something.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
BTW -- what are those 4 little circular thingys on each side of the chassis?Testing
Testing
Testing -
Dennis Gardner wrote:The heatsinks look like they are serving no purpose in those photos to me. I'm sure I'm missing something.Testing
Testing
Testing -
Zero wrote:Early,
They are mosfets.Testing
Testing
Testing -
Bipolars can look like Mosfets when they are in a "can" (the metal encasing). Not all bipolars come in a "can". It just depends on who/how they are manufactured."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
Zero wrote:...Cool amplifier.. one of the better sounding class A/B amp's I've heard for the price (at least, when ran direct). I hope she sings for you!
Sounds great so far. Still waiting on my tube pre to arrive. Then we'll see how the Marsh with tube pre stacks up against the Jolida tube int. amp.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
heiney9 wrote:Bipolars can look like Mosfets when they are in a "can" (the metal encasing). Not all bipolars come in a "can". It just depends on who/how they are manufactured.Testing
Testing
Testing -
GV#27 wrote:Marsh does use bipolars for his outputs though.
Agreed"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Zero wrote:Early,
I look forward to reading your impressions.
Yes, impressions once you have had a chance to break her in."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Yes I would also like to know your impressions.I bet you will like it a lot.
It is very nicely put together and designed by a great engineer.Testing
Testing
Testing -
I noticed that when powered on, the Marsh has these little red lights (4 pair plus two up front) on the circuit board that light up. Does anyone know what their function is?
If you take another look at the pics I posted, the lights run horizontal in the middle of the board.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Sometimes LED's are used in bias circuits instead of regular diodes.Maybe thats the case with this unit?Testing
Testing
Testing -
Did I mention these are some good pics?:D
dorokusai wrote:You guys are lame....imagine re-tubing this to the tune of 22 tubes....
dorokusai what make is this? (Possibly a BSR ADC B100?) -
The ADC B100 had 13 tubes, all 6DJ8's. I (briefly) owned one and posted a photo or two of it earlier in this thread (post #139).
My 350a developed a problem in the last few weeks; the right channel was going on and off; I could fix it by touching/moving the RCA plug; another thing I noticed was that the center (vocals) were all over the place...sometimes to the right, sometimes to the left, sometimes dead center....
So I decided to get the original RCA jacks (Thanks to Dave Belles who pointed me to the right place to get them) and changed them today; the problem was not the jack itself, but the solder on the board was broken (not sure if it can be seen in the picture..the little connections to the right; the big ones are just to fix the jack to the board).
Edit: yes, it can be seen if the picture is enlarged to the original resolution)
Anyway, the problem is fixed and thought I'd share some guts:)
The toroidal is almost 4" high and diameter is 7"....never seen such a big one_________________________________________________
Kahuna wrote:dorokusai what make is this? (Possibly a BSR ADC B100?)
It's a Fisher 400...not exact on the year but its old.
Good work HTrookie. The broken joint is easy to see in that pic and a common problem in gear. Well, common in that I've seen that as a simple fix for a bunch of gear over the years. That, and fuses.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Picked up a vintage Sansui Eight receiver (circa '73-75) a couple days ago just for the heck of it and to have something to play with (it only cost $35).
It had some scratchy controls, which I fixed with Deoxit and cycling. Also cleaned the inside of the unit.
It's been fun to work on a vintage piece from when I was just out of diapers. Maybe my first re-cap job is next. This thing is built well and heavy (almost 40 lbs), has solid aluminum knobs and face, walnut case, and the classic 70's vibe. I've been hanging out a little in the Sansui forum over at audiokarma.org. This old Sansui stuff has quite a following.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
Looks nice.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Innersound Active Crossover / 600 wpc (Bass) Amplifier with Remote!Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Thats a fine lookin piece ,nicely put together .The remote is a nice touch also being able to adjust bass level from the listening chair is a bonus.
What kind of woofers are you using with the ESL,s?Testing
Testing
Testing -
Halo wrote:Innersound Crossover (Bass) Amplifier with Remote!
Very pretty stuff Vic.
