replacing mid range on rm II satelite
gatorpa
gatorpa Posts: 1
edited November 2006 in Forum Testing Area
has anyone successfully changed the mid range speaker after purchasing a part from polk or should it be left up to the pro's?
Post edited by gatorpa on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    I'm not totally familiar with the RM II, but I have done it on my RM 2300 sats.
    Pull the grill, and then remove the rubber grill post inserts that hold the grill into the holes. This reveals 4 screws in those holes that hold on the driver retainer frames. Once this is done, the drivers are free to be taken out of their mountings.
    Hope this helps.
    DG
