replacing mid range on rm II satelite
gatorpa
has anyone successfully changed the mid range speaker after purchasing a part from polk or should it be left up to the pro's?
Post edited by gatorpa on
I'm not totally familiar with the RM II, but I have done it on my RM 2300 sats.
Pull the grill, and then remove the rubber grill post inserts that hold the grill into the holes. This reveals 4 screws in those holes that hold on the driver retainer frames. Once this is done, the drivers are free to be taken out of their mountings.
Hope this helps.
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
