Audio Coaxial? - Does it matter?
lofmarks
lofmarks Posts: 23
Soooo many brands to choose from... does it matter?
Seems they range from $40 - $100!!!!
Thanks in advance,
lofmarks
Post edited by lofmarks on
  • Schwingding
    Schwingding Posts: 363
    edited November 2006
    Rather than trusting anyone else (we all have opinions but offer little proof), try something yourself. Buy one expensive and one cheap cable. Sit in front of your speakers, with your eyes closed and have someone else swap the cables back and forth. If you can reliably tell one from the other (you won't be able to do so) buy that one.
    FWIW, buy the "premium" cables from monoprice.com. They're still extraordinarily less expensive than in the stores, and better quality, too.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • amulford
    amulford Posts: 5,020
    He's right. You'll get alot of POV. The best thing is to try it out for your self and see what you think.
  • wallstreet
    wallstreet Posts: 1,405
    on digital cables, i'm not concerned on boutique cables. Analog cables I am concerned with cable quality.
  • Sansui
    Sansui Posts: 372
    I second that! I was going to locally buy a 6' optical audio cable (because I couldn't find a longer one). Around here the stores are charging about $25.00+ for the Monster Cable brand. My son told me to order it from monoprice.com because that's where he orders cables from. He said that they have a good online reputation for quality and prompt shipping.
    My amp has two ports for optical input so I bought two 12' cables (with shipping/ground) which cost me a little over $12.00. I got them in five days. They both work perfectly.
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
