Audio Coaxial? - Does it matter?
lofmarks
Soooo many brands to choose from... does it matter?
Seems they range from $40 - $100!!!!
Thanks in advance,
lofmarks
Thanks in advance,
lofmarks
Post edited by lofmarks on
Rather than trusting anyone else (we all have opinions but offer little proof), try something yourself. Buy one expensive and one cheap cable. Sit in front of your speakers, with your eyes closed and have someone else swap the cables back and forth. If you can reliably tell one from the other (you won't be able to do so) buy that one.
FWIW, buy the "premium" cables from monoprice.com. They're still extraordinarily less expensive than in the stores, and better quality, too.HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee -
He's right. You'll get alot of POV. The best thing is to try it out for your self and see what you think.
on digital cables, i'm not concerned on boutique cables. Analog cables I am concerned with cable quality.
Schwingding wrote:FWIW, buy the "premium" cables from monoprice.com. They're still extraordinarily less expensive than in the stores, and better quality, too.
I second that! I was going to locally buy a 6' optical audio cable (because I couldn't find a longer one). Around here the stores are charging about $25.00+ for the Monster Cable brand. My son told me to order it from monoprice.com because that's where he orders cables from. He said that they have a good online reputation for quality and prompt shipping.
My amp has two ports for optical input so I bought two 12' cables (with shipping/ground) which cost me a little over $12.00. I got them in five days. They both work perfectly.Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
