My Last Speaker Purchase (I'm serious)
2
  • MSALLA
    MSALLA Posts: 1,602
    edited November 2006
    Damn, they are sweeeet!!!!!
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Loud & Clear
    Loud & Clear Posts: 1,538
    I'm a firm believer in large speakers. Little ones never did it for me. Glad you found the excitement gained by lots of air being moved about the room.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • PolkThug
    PolkThug Posts: 7,532
  • dane_peterson
    dane_peterson Posts: 1,903
    They look great. So if you're done buying speakers... at least for a while, what's the next purchase? Cuz we all know it's always something.
  • george daniel
    george daniel Posts: 12,096
    Congratulations, Brad,,I'll give em' six months :eek: :D
  • Early B.
    Early B. Posts: 7,900
    These VMPS speakers are so good, they're begging for better associated gear. Right now they're powered off my receiver with music being played via a DVD player. As a result, I haven't even begun to hear what these speakers can actually do. It seems like such a waste to have big, bad-**** speakers and not take full advantage of them. So it presents a conundrum for me -- to upgrade or not to upgrade. And if I choose to upgrade, at what level should I go?
    Here are my options for improving 2-channel performance:
    Option #1: SS amp, tube pre, CDP
    Option #2: int. amp (tube or SS), CDP
    Option #3: int. amp, MF tube buffer
    Option #4: combine my 2-channel & HT systems
    Option #5: do nothing
    Option #6: MF tube buffer only
    The “best” options (#1 & #2) are costly ones – I’m guessing $2K - $3K. Based on my current financial situation, I’m reluctant to spend that kind of money on audio right now.
    The “cheapest” option (#4) would actually put money in my pocket, but would require dismantling the reference rig.
    I bought these speakers to pull HT duty only, and they want to do more than that. Ideally, I'd love to power the speakers with something like an Odyssey Stratos (or another hardcore amp) with a tube pre and a nice CDP. But again, the question is: “Is it worth it?”
    "God grooves with tubes."
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Option #1 for nowhere near 2K...
    Come on EB, you know it can be done.
  • Early B.
    Yeah, but I wanna do it right the first time. Sure, I could get a decent 2-channel amp, an entry level tube pre, and a CDP for about $1,200, but that ain't gonna git 'er done.
    Don't forget about accessories -- interconnects, power cords, tubes, vibration isolation, etc.
  • zombie boy 2000
    You're right... but that's the beauty of buying used. You know as well as I do that you're never going to reach the top of the mountain on the first go, so you may as well enjoy the journey. If not entry-level, go a step up and just make sure to set yourself up to break even on resale.
    Option #4 also seems viable, but will take alot of fun out of the hobby IMO.
  • Early B.
    Agreed, although Option #4 is the most practical solution -- the best of both worlds. However, I like the idea of having two separate systems. Besides, the ambience and acoustics in the 2-channel room are much better, and since I listen mainly to jazz, that's an important consideration.
  • zombie boy 2000
    So we're in agreement... scrap all plans for a one-rig solution. So I guess my next question is -- which system is going to be your two-channel set-up? It sounds like the Tylers might be relegated to HT duty?
  • Early B.
    Oh, no. The Taylos remain in the reference rig. Besides, any floorstander would be too big to put in the 2-channel room, especially the VMPS'.
    There's an option #7 -- if I'm gonna dump all that money into making my VMPS' sound better with music, instead of doing that, why not use this money for beefing up the reference rig? If I do this, I'll keep true to the original intent of the VMPS -- HT duty only.
    Damn. Too many options.
  • zombie boy 2000
    Ahhhhhhhhhhhhhhhhhhhhhh..... so we're still talking HT. And multi-channel pre's...
    Too many options indeed. Let me wrap my lil' undead brain around this one:p
  • Early B.
    Oh, just thought of Option #8: Upgrade the CDP and int. amp on my 2-channel system and migrate existing components to the HT system.
    I'm feelin' this option.
  • zombie boy 2000
    I'm feelin' it only because it might free up your Bada:D
  • Early B.
    Nope. The Bada goes to the HT system.
  • Early B.
    OK, after hooking up my tube CDP to the HT system, I made a decision -- just purchase a 2-channel amp to power the fronts and forget about building another 2-channel system.
  • Joey_V
    Joey_V Posts: 8,600
    So what happens to the Tylers?
  • Early B.
    Them Tylers ain't goin' anywhere. However....
    Gonna check out some VMPS 626R's over the weekend. It'll be interesting to hear some ribbon tweeters.
  • Joey_V
    Joey_V Posts: 8,600
    Wow... if this review of a modded one proves sort of true for the base model, you should be in for a treat Brad.
    Joey
    http://www.positive-feedback.com/Issue15/vmps626R.htm
  • Early B.
    Put this thread in your time capsules, fellas.
    A year from now I'm gonna pull this thread back up and scream, "IN YOUR FACE, YOU SUCKERS!!" 'cause I'll still have these speakers. :eek:
  • george daniel
    Somehow I seriously doubt that :D
  • hoosier21
    hoosier21 Posts: 4,416
    Do these 626R have the spiral or FST tweeter? The spiral is good, just that the FST is the real deal.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Early B.
    Don't know yet. I'd love to her them both. There's a VMPS dealer in town, so I'm gonna visit him this weekend.
  • hoosier21
    there is a special going on with the 626R right now, go to audiocircle.com and read. 995.00 with spiral tweeter, add 200.00 for the mega woofer.
  • Joey_V
    Joey_V Posts: 8,600
    I'm bookmarking this thread so that I can rub this in Brad's face next year.
  • hearingimpared
    hearingimpared Posts: 21,136
    Wow they really are BEAUTIFUL. . . they even have that stressed wood look, all the craze on HGTV designers shows.:cool:
    Feeling a little green.:D
  • Early B.
    Yeah, I saw those advertised on the VMPS website. Damn. Almost wish I hadn't seen'd 'em.
    I wonder how they sound compared to the Taylos. Hmmmm.
  • Early B.
    edited April 2008
    Hey fellas --
    For all you doubters out there (especially you, George D.), I decided to dig up this old thread and remind all of you that I said this was my last speaker purchase (see also post #54). Still got 'em and goin' strong all day long.
    Ha! In yo' face, beetches!!!! Do you believe me now?
    Say my name!!! What? I don't hear you. Say it again!!! [...he says, as he does the happy dance...]
  • MKZ
    MKZ Posts: 1,068
    edited April 2008
    Good to hear that. What about CABLES?;)
