Home Theatre Recommendations
jjosport
I have a 55" HD wide screen, a DVD player, Tivo and a cable box. I want to put a better audio system that will allow me to use the system for music as well as to enhance my DVD and TV experiences.
I don't want to have to spend a lot, or anything for that matter, on install but I want something that I can integrate all of my equipment into.
Any suggestions?
Thank you,
JJO
Any suggestions?
Thank you,
JJO
Thank you,
Jim Oremland
Jim Oremland
Post edited by jjosport on
I assume you will need everything -
Front Speakers
Center Channel
Rear speakers (5.1 for now)
Subwoofer
Reciever (or amp/preamp)
all cables and wiring to make it happen.
What is your budget and preferences? (5.1, 7.1, 2 channel with SDA speakers) Amp/Preamp ok or would you prefer an AVR? Used ok or do you really want new?
What speakers do you like? Are you really 50-50 for music and movies? We can spend as much as you let us, it all comes down to budget (and the sound you want of course).
Yes, I probably need everything.
Usage is about 80% TV for wife. She complains the TV speakers are not that good. Even though I have tweaked the sound, she has difficulty with voices.
I'd prefer only three speakers, including a subwoofer, so I don't have to wire rear speakers.
I was in a Tweeters and they recommended a pair of Polk speakers, a subwoofer and a Yamaha receiver.
I don't want floor speakers and my wife loves the look of the cubes from Bose. I was fine with the Polk speakers. The reputation is terrific and I'm in Maryland too.Thank you,
Jim Oremland -
Probably should have described the room:
Family room that opens into dining area. 20 x 20 is main room area.Thank you,
Jim Oremland -
Welcome! What is your budget?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
cfrizz wrote:Welcome! What is your budget?
Although it's whatever I want it to be, I'd like to stay under $750 if I can. Is that reasonable?Thank you,
Jim Oremland -
A pair of RT4's or Monitor 30's, an entry level receiver(like a Denon 1507), and an entry level sub(PSW10) could get within your budget.
Front speakers: $200-$260
Subwoofer: $200
Receiver: $329
Cables: $50-$75
Total Price: $780-$865
For a little cheaper receiver that does most of the same functions, you can check out a refurbished Denon from www.ecost.com, specifically this page: http://www.ecost.com/ecost/search/search.asp
You might also check out the surroundbar, with subwoofer, as an alternative to the RT4's. This will give you really good surround sound and I don't think the music will be that bad either.Tschüss
Zach
