Home Theatre Recommendations
jjosport
jjosport Posts: 4
I have a 55" HD wide screen, a DVD player, Tivo and a cable box. I want to put a better audio system that will allow me to use the system for music as well as to enhance my DVD and TV experiences.
I don't want to have to spend a lot, or anything for that matter, on install but I want something that I can integrate all of my equipment into.
Any suggestions?
Thank you,
JJO
Thank you,
Jim Oremland
Post edited by jjosport on
  • McLoki
    McLoki Posts: 5,231
    edited November 2006
    I assume you will need everything -
    Front Speakers
    Center Channel
    Rear speakers (5.1 for now)
    Subwoofer
    Reciever (or amp/preamp)
    all cables and wiring to make it happen.
    What is your budget and preferences? (5.1, 7.1, 2 channel with SDA speakers) Amp/Preamp ok or would you prefer an AVR? Used ok or do you really want new?
    What speakers do you like? Are you really 50-50 for music and movies? We can spend as much as you let us, it all comes down to budget (and the sound you want of course).
    Michael
  • jjosport
    jjosport Posts: 4
    Yes, I probably need everything.
    Usage is about 80% TV for wife. She complains the TV speakers are not that good. Even though I have tweaked the sound, she has difficulty with voices.
    I'd prefer only three speakers, including a subwoofer, so I don't have to wire rear speakers.
    I was in a Tweeters and they recommended a pair of Polk speakers, a subwoofer and a Yamaha receiver.
    I don't want floor speakers and my wife loves the look of the cubes from Bose. I was fine with the Polk speakers. The reputation is terrific and I'm in Maryland too.
    Thank you,
    Jim Oremland
  • jjosport
    jjosport Posts: 4
    Probably should have described the room:
    Family room that opens into dining area. 20 x 20 is main room area.
    Thank you,
    Jim Oremland
  • cfrizz
    cfrizz Posts: 13,415
    Welcome! What is your budget?
  • jjosport
    jjosport Posts: 4
    Although it's whatever I want it to be, I'd like to stay under $750 if I can. Is that reasonable?
    Thank you,
    Jim Oremland
  • okiepolkie
    okiepolkie Posts: 2,258
    A pair of RT4's or Monitor 30's, an entry level receiver(like a Denon 1507), and an entry level sub(PSW10) could get within your budget.
    Front speakers: $200-$260
    Subwoofer: $200
    Receiver: $329
    Cables: $50-$75
    Total Price: $780-$865
    For a little cheaper receiver that does most of the same functions, you can check out a refurbished Denon from www.ecost.com, specifically this page: http://www.ecost.com/ecost/search/search.asp
    You might also check out the surroundbar, with subwoofer, as an alternative to the RT4's. This will give you really good surround sound and I don't think the music will be that bad either.
    Tschüss
    Zach
