Richard Gray 1200S Power Conditioner
wingnut4772
I am thinking about getting THIS 1200S for my system and was wondering if anyone here has one or knows anything about them. I would be replacing my Monster HTS 2500.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
looks awesome, however the site doesnt mention switched outlets, filtration of any sort. How does this unit go for. Have you looking into the higher end monster, Panamax, Belkins? Maybe this unit is the ****, no personal experience from myself. Good Luck, if you dont mind me asking why are you getting rid of the 2500?
Not sure if you seen this but here is a review of the product.http://www.audaud.com/audaud/MAY01/EQUIP/equip1MAY01.htmlShoot the jumper.....................BALLIN.............!!!!!
Darla, check out the new units from PS Audio. They seem to have come up with something special.Political Correctness'.........defined
President of Club Polk -
Sherardp wrote:looks awesome, however the site doesnt mention switched outlets, filtration of any sort. How does this unit go for. Have you looking into the higher end monster, Panamax, Belkins? Maybe this unit is the ****, no personal experience from myself. Good Luck, if you dont mind me asking why are you getting rid of the 2500?
I was interested in the 1200 because it is supposedly non-current limiting and made for a 20 amp circuit ( I have one).
I have no complaints with the 2500 but I am always looking to improve the HT performance and I have read sopme good stuff about these. The 1200 also has 2 more outlets.
The 1200 reatails new for about 2k (list) but it is going for about 1K - 1200 used on the Bay and the Gon.
Just wondering if 13k work of pre and amps might be better served hooked up to this rather than the $300.00 Monster.
Thanks for the review link. I read all I could find and they are all positive with the excepton of Stereophile's. They are actually downright negative.
I will take a look at the PS Audio.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Most of the things I've read about the Richard Gray products have not been all that complimentary. I haven't owned one myself though. Stereophile said this about the 400S:If you have an early-CD-sound solid-state system and you want to smooth off its rough edges, be my guest. The 400S would probably work well in that context. But if you have anything resembling a carefully set-up, high-resolution system, I suggest you spend your money elsewhere.
I'll second the PS Audio suggestion. The Richard Gray products seem to me to be little more than a surge suppressor in a fancy box. The logo doesn't look very appealing to me.
The new PS Audio line looks promising. I can recommend any of the three older products of theirs I use without hesitation. They replaced Monster HTS5100 units and made a big difference. -
well hurry up so i can get that monster unit from ya
I kid i kid
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
A few years back, I tried several conditioners. Among them was a Richard Gray unit. In my trials, I could not find any benefit using this product in my system.
I will also suggest you have a look at the new PS Audio Premier Power Plant or the ExactPower EP15A and SP15A combination. If you have problems with noise or voltage fluctuations in your area, one of the above two would be a primary candidate for your next purchase.
As I do not have any problems with voltage flucations or too much line noise, I decided on using a BP-2.5 Ultra with Bybee Quantum Purifiers and a differential noise filter (now the HFC-30). This has made a huge difference in my system. My next acquisition will be a black EP15A to complete the power management portion of my system.
I would suggest trying anything you can get your hands on in your system to determine the net results. What I or others experience may not be what you would experience in your system.
Arthur SchopenhauerAll truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
Ok, I picked up the Richard Gray 1200s AND I got the PS Audio Premier Power Plant . I am going to try them both and see which I prefer. The PS Audio has a 30 day return policy and I can re-sell the RGPC on the GON depending on the winner.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Did you get the $200 off special deal on the PS Audio unit? It's valid for September.
If you have one available, use a PS Audio Statement power cord (current or previous design cord) from the unit to the wall. -
Emlyn wrote:Did you get the $200 off special deal on the PS Audio unit? It's valid for September.
I think that is only from local dealers. I ordered it online but I did not have tp pay tax so it worked out pretty much.
I don't have a PS cord...um...I guess it doesn't come with one...?:oSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
The stock cords with PS Audio power conditioners are usually generic 14 AWG or 12 AWG cords. Any aftermarket cord will work better than the stock cord. The previous generation Statement cords are still available on the used market for around $200.
Kinda tough to beat a great deal like this...
http://www.audioadvisor.com/store/productdetail.asp?sku=PSAPRPC1%2E5&product_name=Prelude%20Power%20CableHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I had the tripplite LCR-2400 power conditioner for quite some time. Never really noticed what it did until I sold it. The sound became somewhat rougher, less smooth. Overall a cheapening of the sound quality. I'm guessing most conditioners are like this. Pretty much you have to get used to it being in line and then if removed it is quite noticeable. I will probably try a Richard Gray unit at some point but as of now I have not so my comments are useless. As a matter of fact I don't even know why I'm writing this...
I got it in in and hooked it up last night. So far all I can say is that everything that is reported about the video image is abolutely true. Even my partner commented that the PQ was 'clearer'. My HD images which I thought were terrific before are almost stunning now - and I don't even get my set calibrated until Oct. The jury is still out on the audio side.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
**** it better make me breakfast for that price.. and if i bought it, id be making my own breakfast anyways
If it makes a notable difference that's great!!!!!
But that is alot of cash even if i had it, to throw in a PC...... however now it works out for ya, send that monster this way
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
wingnut4772 wrote:I got it in in and hooked it up last night.
Which one? -
okiepolkie wrote:Are you planning to get your set ISF calibrated?
Yep. Eliab from Avical will be here in Oct.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Emlyn wrote:Which one?
Oh Yes:o The Richard Gray. I am considering canceling the PS Audio order. That may be too rich for me for something so new right now. I will see.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
wingnut4772 wrote:Oh Yes:o The Richard Gray. I am considering canceling the PS Audio order. That may be too rich for me for something so new right now. I will see.
You have 30 days to trial the product. Just the balanced power output capabilities of the unit may provide the same benefits as the RG unit. You also get clean regulated power as well as many other features that should benefit your entire system.
Just some food for thought.
Early B. wrote:Kinda tough to beat a great deal like this...
EB, have you used this cable in particular? I need another high end cable to match up with my other anthem which is just the stock version. The Power 3 that came with one amp doesn't have a snug fit, so you have to kind of rig it in place. This one claims to be a tight fit.UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team -
univera wrote:EB, have you used this cable in particular? I need another high end cable to match up with my other anthem which is just the stock version. The Power 3 that came with one amp doesn't have a snug fit, so you have to kind of rig it in place. This one claims to be a tight fit.
The PS Audio power cords fit as tight as a virgin's panties. Just buy it.
Oops. No offense to virgins. I should have said, "...as tight as a fat girl in spandex."HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I second the virgin's panties. Just buy it.Political Correctness'.........defined
So, has the PSAudio unit unveiled its head yet?
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
No. They don't ship until late Oct. After participating and reading the PS Audio forums I think I will wait until some other user feedback comes in on them. I seem to be getting some conflicting info.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Well, that's a bummer. My eye has just been drawn to some new UPC-200's going on a-gon for $238.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I have been thinking of the UPC 200 as well. I have read a couple of sources regarding the improvement on the Nuforce ref 8's with the unit. I am wondering if it could offer the ref 9's the same. The cheapest I have seen it up here was 385.00 on CanuckAudioMart.
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
Here's one on agon for $295 that will ship to Canada. Here's a modded one for $309 that will ship worldwide.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
wingnut4772 wrote:No. They don't ship until late Oct. After participating and reading the PS Audio forums I think I will wait until some other user feedback comes in on them. I seem to be getting some conflicting info.
Interesting read; based on prior experience with a P300, actual current draws are somewhat less than you would expect.
There are devices that can measue current draw. This one is rated for 15A. If I recall correctly, this may not work for your amp as it has a 20A plug, but you could look for a 20 to 15A adaptor or build a cheap power cord from parts found at Home Depot. This way you could measure actual values and make an informed decision.
audiobliss wrote:
Thanks Bliss. I have never bought anything used from the US. I am not sure how bringing it across the boarder works. Not sure if there are similiar fees, etc.?
Consonance cd120T
Usher CP 6311
Unfortunatley, all I can say is 'ditto'. As I'm sure you have, I've read of a lot of troubles with shipping across the border. But I don't really know how it works.
Good luck with your search, though!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
