Tweeter in one of my LSi9 is not at crisp as the other?
Shannon W.
I just did a test on my speakers to see why the Right speaker is more dominate then the other. Well to my surprise the Left tweeter is not as crisp as the right "its almost muffled". So what to do now? Thanks! Shannon
50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
First try switching the speakers on the the back of your amp... and see if the problem follows the speaker.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
Thanks! Shannon50" Samsung Plasma
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
So the same speaker is still muffled? Or the same side?I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
The driver with one of the others that I have and still no change. chould this be a X-over probem? I have a spare of of those that was repalce out of my LSiC back in 2002 due to a rainbow efect it was giving my CRT. Thanks! Shannon50" Samsung Plasma
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Have you checked the brass jumpers on the back to make sure they're secure to the binding posts?I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
so no Jumpers.50" Samsung Plasma
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
It's hard to keep things crisp once the bag is opened. Have you tried burping your Vifa?"she had the body of Venus, with arms."
50" Samsung Plasma
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
I believe the crossover in the LSiC is different than the one in the LSi9, so if I were you I wouldn't swap them. If you've tried swapping to a different channel on your amp/reciever, and swapped out the tweeter, then yes it probably is the crossover.
Give polk customer service a call, and explain the problem. They will take good care of you. Let us know how it works out! -
I had a similar problem on my Rti10's. I first tried switching the L/R amp channels to see if the problem moved or stayed with the speaker, then I switched the tweeters between the 2 cabinets to see if the tweeter was the problem. After all that, the sound remained with the same speaker cabinet, so I removed the crossover and sent it to Polk, they sent me a replacement and that fixed the problem.
Eric__________________
Pioneer 1015
Rotel 1080
Rotel 1075
Rti10: L/R
Rti5: C
Rti6: LS/RS/LSB/RSB
SVS pb10-isd
