Tweeter in one of my LSi9 is not at crisp as the other?
Shannon W.
Shannon W. Posts: 568
edited August 2006 in Speakers
I just did a test on my speakers to see why the Right speaker is more dominate then the other. Well to my surprise the Left tweeter is not as crisp as the right "it’s almost muffled". So what to do now? Thanks! Shannon :confused:
50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited August 2006
    First try switching the speakers on the the back of your amp... and see if the problem follows the speaker.
  • Shannon W.
    edited August 2006
    Thanks! Shannon
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • zombie boy 2000
    edited August 2006
    So the same speaker is still muffled? Or the same side?
  • Shannon W.
    edited August 2006
    The driver with one of the others that I have and still no change. chould this be a X-over probem? I have a spare of of those that was repalce out of my LSiC back in 2002 due to a rainbow efect it was giving my CRT. Thanks! Shannon
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • zombie boy 2000
    edited August 2006
    Have you checked the brass jumpers on the back to make sure they're secure to the binding posts?
  • Shannon W.
    edited August 2006
    so no Jumpers.
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • ninerbj
    ninerbj Posts: 870
    edited August 2006
    It's hard to keep things crisp once the bag is opened. Have you tried burping your Vifa?
    "she had the body of Venus, with arms."
  • Shannon W.
    edited August 2006
    :confused:
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • phuz
    phuz Posts: 2,372
    edited August 2006
    I believe the crossover in the LSiC is different than the one in the LSi9, so if I were you I wouldn't swap them. If you've tried swapping to a different channel on your amp/reciever, and swapped out the tweeter, then yes it probably is the crossover.
    Give polk customer service a call, and explain the problem. They will take good care of you. Let us know how it works out!
  • EricBurg
    EricBurg Posts: 64
    edited August 2006
    I had a similar problem on my Rti10's. I first tried switching the L/R amp channels to see if the problem moved or stayed with the speaker, then I switched the tweeters between the 2 cabinets to see if the tweeter was the problem. After all that, the sound remained with the same speaker cabinet, so I removed the crossover and sent it to Polk, they sent me a replacement and that fixed the problem.
    Eric
    __________________
    Pioneer 1015
    Rotel 1080
    Rotel 1075
    Rti10: L/R
    Rti5: C
    Rti6: LS/RS/LSB/RSB
    SVS pb10-isd
