7.1 Opinions
808Tech
Hey guys, I looked around, and I felt this is the best place to start a thread on this...
I just pre-wired for a 7.1 system. The gentlemen's room is 12' x 33'. The 119 inch projection screen is going to be on the 12' wall. I've heard alot of different opinions on speaker placement for 7.1, but what's your opinion? This isn't the ideal room size for a theater system, but what's your personal opinion?
Thanks alot
Thanks alot
Post edited by 808Tech on
pre-wired?
"Gentlemen's room" you said?
You should definitely look into inwalls. The LCi series would be a great start.
No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR -
The sides should be slightly behind your listening position so they don't cancel out signals from the front mains. Rears can be in the corners, or behind your seating.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
