Cheap speed...Mustang or Camaro?
2
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    audiobliss wrote:
    Anybody know of some good Mustang magazines I could check out? I'll look through them next time I go to the grocery store or the book store, but it's hard to decide which one(s) is(are) worth subscribing to in just a sitting.
    Thanks!
    Check out Muscle Mustangs & Fast Fords, 5.0 Mustang, and Modified Mustangs for the most Fox body coverage. I subscribe to all three ;)
  • audiobliss
    audiobliss Posts: 12,518
    edited August 2006
    Awesome. Thanks for the suggestions. I just might follow suit and fill out some subscription forms, too. :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    You're welcome. Also, check out SVTOA National. I think there is a NC chapter. This is the group within Ford responsible for such vehicles as the GT500, Cobra models, and Lightning trucks. I belong to the Memphis chapter. This will give you more contacts in your area, and might even help you find a cheaper car to start out with. Good luck with your search!! :)
  • shack
    shack Posts: 11,154
    edited August 2006
    audiobliss wrote:
    It's beginning to look like it's going to take at least $2000 for just the car. Oh well...we'll see...
    That IS cheap. You can't buy a 4 cyl. Ford Ranger pickup that was a fleet vehicle with 200,000 mile on the odometer for much less than $1,500. You gotta be carefull though. A lot of 5.0 Mustangs have been flogged to death and it will cost you more to get it in good running order than it's worth. A good suggestion is to find a decent 4 cyl. car that has been treated well. Find a 5.0 drivetrain and build it and drop it in. There are several companies that will sell you everything you need for the swap or most of the mags you have listed have swap articles. The coupes may be the fox body to have. Most of the 5.0s sold were the GTs and fastbacks. Lots of the coupes (or notchbacks) were used for drag cars because they are several hundred pound less than the fastbacks. Nice unmodified stock coupes in decent conditon are becoming very hard to find. I'm slowly putting mine back to showroom stock condition.
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    Sweet notch Shack!
  • audiobliss
    edited August 2006
    Very nice looking Stang!
    I'm beginning to be glad this is something we're 'gonna do' in a few years time as opposed to now, as I'm getting really confused over what path to take, lol. I'll just have to do a bit more research and see what I find out.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • shack
    shack Posts: 11,154
    edited August 2006
    MattN03 wrote:
    Sweet notch Shack!
    Sorry guys. That one isn't mine. It belongs to Ron Berry (and he has done a beautiful job with it). It was next to mine in my pic file and I didn't realize I uploaded the wrong one. Here's mine.
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    lol, that's a good looking Fox too :D
  • audiobliss
    edited August 2006
    I like that lighter color. Keep me informed as you do stuff to it; I'd be interested in reading about it.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • shack
    shack Posts: 11,154
    edited August 2006
    I'm not doing anything all that interesting. Taking it back to very close to stock. Actually it really is now with the only non stock items on the car are an upgraded radiator, sport shocks and camber/caster adjustment plates . It has 180,000 miles on it (i'm the original owner). I'm just doing little things now, like replacing door hinges, new carpet, seat covers, water pump, etc. I need to rebuild the rear end as it had a axle seal go bad. Tranny probably needs some attention to (maybe time for a clutch). The only changes I plan to make at all would be rear disc brakes and a little better breathing cat-back exhaust system. The engine has never had the valve covers pulled and still has good compression, however with that many miles I may want to consider a rebuild. The reason I want to go this route is because a stock 5.0 coupe will be/is a rarity. You seldom see one that hasn't been modded with a fiberglass hood, wheels, extensive engine mods and so forth. I guess I just want to be different. Ron's car is really how I want mine to look when its finished. However Even though his looks stock he has made a few engine and drivetrain mods and currently makes 525 horspower and 480 lb/ft. at the rear wheels (per dyno).
    In case you are interested in his mods....
    Engine Modifications:
    Vortech S-Trim Supercharger with 3.33” Pulley (16 psi @5800 rpm)
    Vortech Renegade 8" Crank Pulley
    PA Performance Supercharger Belt Tensioner
    Edelbrock 6037 Aluminum Cylinder Heads
    Trick Flow “Street” Intake Manifold
    Trick Flow 3/8" Phenolic Intake Spacer
    FRPP 65 mm Throttle Body and Spacer
    Pro-M 80 mm MAF with Conical Air Filter
    Dynotech "Boostmaster" 4" Inlet Pipe
    Crane 2031 Cam, Valvesprings and Retainers
    Crane “Cobra” 1.7 Roller Rocker Arms
    FRPP Black Finned Aluminum Rocker Covers
    FRPP 42 lb/hr Fuel Injectors
    SN95 Fuel Rails
    Kirban Adjustable Fuel Pressure Regulator
    Walbro GSS340 255 lph Fuel Pump
    BBK Inline Fuel Pump
    Powerbond SFI Harmonic Balancer
    ASP 1 7/8" Overdrive Alternator Pulley
    93 Cobra Overdrive Water Pump Pulley
    Crane HI-6R Ignition with TRC-2 Boost **** and PS91 Coil
    FRPP Aluminum Radiator
    Police Fan Clutch
    180 Degree Thermostat
    SCT Custom Chip by Brad Brand - Atlanta Chassis Dyno
    Exhaust Modifications:
    FRPP 1 5/8" Ceramic Coated Stainless Steel Shorty Headers
    Bassani 2 1/2" Catalytic X-Pipe
    Dynomax 2 1/2" Super-Turbo Cat-Back Exhaust
    Stage 8 Locking Header Bolts
    Drivetrain Modifications:
    Tremec T5Z Transmission
    Pro 5.0 Shifter
    FRPP Leather Shifter Knob
    SPEC Stage III Clutch and Pressure Plate
    SPEC Aluminum Flywheel
    BBK Adjustable Cable & Quadrant
    FRPP Aluminum Drive Shaft
    HP Motorsports Driveshaft Loop
    FRPP 3.73 to 1 Rear Axle Gear
    FRPP 31 Spline Traction-Lok (Repacked with 8 Clutches)
    Moser 31 Spline Axles with 3" Studs
    Suspension Modifications:
    2001 Bullitt Springs (1 Coil Removed on Front)
    Tokico High Performance (Blue) Struts & Shocks
    Dugan Racing Sub-Frame Connectors
    Dugan Racing 2 Point G-Load Brace
    Maximum Motorsports Weight Jacker Lower Control Arms
    FRPP HD Upper Control Arms
    Polyurethane Sway Bar, End Link, Spring Isolators & Strut Bushings
    Dunlop SP Sport FM901 225/50VR-16 Tires on Front
    Nitto NT 555R Drag Radial 245/50VR-16 Tires on Rear
    Brake Modifications:
    SN95 1-1/16" Bore Master Cylinder and Brake Booster
    73mm Piston Front Brake Calipers
    Maximum Motorsports Stainless Steel Caliper Bushings
    Maximum Motorsports Stainless Steel Brake Lines
    Power Slot Front Brake Rotors
    Performance Friction Brake Pads
    SSBC 10.5" Rear Disc Brake Conversion
    Maximum Motorsports Adjustable Proportioning Valve
    And also VERY important:
    Stereo System:
    Sony CDX-F5700 In-Dash AM/FM/CD/MP3 Head Unit
    Infinity Reference 3002cf 3.5" Dash Mount Speakers
    Polk Audio EX365 6.5" Two-Way Door Mount Speakers
    Polk Audio EX357 5"x7" Two-Way Deck Mount Speakers
    and a few more pictures...
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2006
    One word SWEET :D
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • faster100
    faster100 Posts: 6,124
    edited August 2006
    even though i favor chevy and have had all chevy.. Nova, camaro, and such.. I have wanted a mustang coupe for years.. The price is certainly gone up for nice ones also
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • danger boy
    danger boy Posts: 15,722
    edited August 2006
    have you looked in wheel Deals in your local area? They have all kinds of junkers that i alway see.. some small car lots have their $499 sale with usually offering a handful of cheap **** cars. i don't know how many of them would be 5.0's though..
    PolkFest 2012, who's going>?
  • audiobliss
    edited August 2006
    Shack - I thought you said just a few mods; look at that list!! :eek: 525hp and 480tq at the wheels is quite impressive. Do you know what it'd do the quarter in? Assuming traction wasn't a problem, I think I'd guess somewhere in the mid to high 11's.
    That really is a beautiful car. The more I think about this, the more I want to just put out ~$3000 and buy a nice one for myself and take care of it, rather than buy a junker and beat it up.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited August 2006
    Ok, I've come to learn that these Fox Body's are highly sought after in certain circles and are becoming rare, hence they're not really that cheap. I've also come to be really fond of their body style, which is weird, 'cause I never was before. So now, at any rate, I'm thinking that I'm going to add a Fox Body to my list of cars to one day own and do right. However, it's definitely not going to fit the bill for what my friend and I are looking for.
    Does anyone have any suggestions for a really cheap car we could put some time and a little money into to get to going fast for a bit of fun? I'd really welcome any advice!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • ND13
    ND13 Posts: 7,601
    edited August 2006
    Bliss,
    I'll sell ya my '94 5.0/5sp GT for $4500!!!:cool:
    Ugh!!!, I can't believe I just used this as my 5k post:o :o
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • faster100
    edited August 2006
    Unless its gonna be for the track or backwoods/roads.. shareing a project car wont work to well, who's gonna register it? will it end up being 50/50 ? someone always ends up paying/spending more.. then when your done with it, who gets it.. and what if one of you is done with the car and the other wont let go of the project..
    Not to be a downer, but if you like cars and want a project.. save, get one while you live at home still so you actually have money to spend on it.. and have it for yourself..
    of course plans that young people have planned for 2-3 years out always change anyways and you may end up wanting to do something totally different.
    Its like Trey saying he's gonna save 30k in the next 5 years and buy a new truck cash.. ya hope he can do it but history shows most people dont stick with it long term
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • audiobliss
    edited August 2006
    Noel, thanks for the offer...and with your 5k post, too! Congrats on finally acheiving that mark, there, grasshopper. :D I'll look up that thread about your Stang again, but I'm pretty sure I'd much rather have a Fox Body. I just don't like the way the 94-98 Mustangs look.
    faster100 - Good point about going in together. I just thought about this yesterday. What about registering? And insurance?! Man, that could get complicated...and pricey!
    I'm really all confused about this now.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • ND13
    ND13 Posts: 7,601
    edited August 2006
    Fox is a chassis, that started back in '79 "based" off of the Fairmont, of all cars. The Fox chassis didn't end until 2004 MY with the introduction of the new 2005 design. I guess some call the bodies Fox, too. I've always went by the chassis.
    Here's some info for ya.
    http://www.moddedmustangs.com/history-of-the-ford-mustang.html
  • sucks2beme
    sucks2beme Posts: 5,684
    edited August 2006
    Last time I co-owned a project car was 30 years ago. 1969 Firebird.
    Yes, I got screwed. Boy, do I wish I had that one now!
    My son did a Accord with a couple of friends. 2/3 his money, most of his time. It went to the guy that wrecked his daily driver.
    He now does his own.
  • Demiurge
    Demiurge Posts: 10,874
    edited August 2006
    Cheap and automobile don't go together.
  • audiobliss
    edited August 2006
    Thanks for the link. There appears to be a lot of good info there. I guess I should have said I prefer the '87-'93 Mustangs. However, I looked back at the pics you posted of your Mustang, and it's so clean it really looks great! You're not seriously still trying to sell it are you?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    I'd stay away from the 96-98 non-PI cars. The non-PI 4.6 is a complete ****-almost no matter what you do (w/o going into the motor and replacing heads, cams, and intake).
    Get a Fox or a 4.6 4 valve IMO. :D
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    94-98 are consider SN95's and the 99-04 are New Edge SN95's ;) Yes, these are a Fox based platform, but it's quite an improvement over the 93 and older Fox.
  • audiobliss
    edited August 2006
    What do you mean by a 'non-PI' car? And his '94 Stang has the 5.0. Is the 4.6 the V6? What does the SN95 stand for?
    Oh, and I just subscribed to Muscle Mustangs & Fast Fords and 5.0 Mustangs & Super Fords. :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • ND13
    ND13 Posts: 7,601
    edited August 2006
    The 4.6 is the V8 that replaced the 5.0. It has a single overhead cam in the GT version and dual overhead cams w/32 valves in the Cobras. It revs higher, but has less useable low-end torque.
  • audiobliss
    edited August 2006
    Did I miss out on what the 'PI' means? Hmm...maybe Port Injection? For some reason I don't think that's it...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • sda2mike
    sda2mike Posts: 3,131
    edited August 2006
    you can go racing with very little or no mods with a 98 z28...i had one for awhile...totally stock it ran a 13.5 @ 105.5...this was with a 2.73 and auto matic! i actually got 31 mpg on the highway! after getting the mods bug, i added the following...intake lid ($80), larger mass air flow meter ($140), Exhaust cut out ($80), 3000 stall converter ($650), 3.73 gears ($650), subframe connectors ($145), computer reprogrammer ($150)..the priced include install...after all that, which isn't much, i got it down to 12.6 @ 110...all i needed to do, i guess was let it breathe better...i still got 28 mpg hwy! great drivetrain as nd13 said. no character though! for a toy, I'd get the ls1 car:D
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    Yes, 94 & 95 have the 5.0 V8. Non-PI stands for Non Power Improved heads & intake. The 99 4.6 V8 got a jump from 215 HP to 260 HP with the PI (Power Improved heads/intake setup). SN95 was the internal Ford lingo for the 94-98 platform.
  • audiobliss
    edited August 2006
    Oh my....my knees...are weak...my mouth...is dry....I'm....in awe...
    Download this video of some guy taking off at the drag strip in his Fox Body and listen to the car behind him I guess getting ready to go after him. Oh my!!!! :eek: That's a hauss, there! I just watched that video at least 4 times in a row with my volume at the half-way point. Yeah, now that's really loud. But that car...oh man, that's what heaven's gonna sound like!!
    Why did he let her rip all the way to redline there nearer the end when the two cars were almost all the way down the stretch? I mean, he certainly didn't need to break the tires loose to warm 'em up. Hmm, maybe he just did it for my pleasure.
    Download it! Listen to it! It's awesome! Linky
    :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
