Front and Centre Call
Paul.Cox
Paul.Cox Posts: 12
edited August 2006 in Speakers
Looking for views and advise on the following. Am about to replace the front speakers to my HT. Due to space want to add bookshelf speakers for the fronts. The speakers are driven by a Denon 2106 AVR, use the biamp option for the fronts to give 5.1 HT.
Have the following;
Centre is monitor CS2
Sub PSW10
Surrounds is a pair monitor 30
Am looking at the following options
1. add a pair of Monitor 40s - lowest cost but is it the best sound option ?
2.Add a pair of RTi6 - but what will this sound like with the CS2 ?
3. Add RTi6 and replace the centre with CSi3 - most expensive option, how much improvement ?
Would appricate the view pts.
Post edited by Paul.Cox on
  • Early B.
    Early B. Posts: 7,900
    edited July 2006
    Go with option #3.
    "God grooves with tubes."
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2006
    go with option 4, pr of Rti8s, CSi5 center, FXi3 surrounds, Rti 4 back surrounds. Huge Improvement, reason I say that is, make the upgrade worth your while even if you have to buy the speakers a pair at a time my friend.
  • schwarcw
    schwarcw Posts: 7,360
    edited July 2006
    I like option #3, next being option #2 followed by #1. The RTi6's have a perfect timbre match with the CSi3's.
    Carl
  • GATOR3000
    GATOR3000 Posts: 355
    edited July 2006
    :) Most definitely option #3. :)
    Theatre System 5.1
    Sumsung HP-S5053 plasma
    Receiver Denon AVR 3806 Pre/Pro
    Parasound HCA 1500A amp (front L/R)
    Parasound HCA 1000A amp (centre)
    B & K AV5000 amp (bi-amp + surround)
    Dynaco ST70 tube amp (Herbie HAL-O9)
    polkaudio Lsi15 (Cherry) 2-channel
    polkaudio Rti8 Front (Cherry)
    polkaudio Csi5 Centre
    polkaudio Rti6 Surround
    polkaudio PSW1000 Subwoofer (Cherry)
    Original A8T CD
    Pioneer DV-275 DVD Player
    MONSTER CABLE MP-HTS3500MKII Powercentre
  • josh_parsons626
    josh_parsons626 Posts: 219
    edited July 2006
    Go with option #5:
    LSi9 fronts
    LSiC center
    LSiFX side surrounds
    LSi9 rear surrounds
    SVS PB12-Ultra/2 Subwoofer
    Outlaw Audio 990 Pre/Pro
    Outlaw Audio 7700 7-Channel Amp
    Good to go my friend!
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
  • ohskigod
    ohskigod Posts: 6,505
    edited July 2006
    option 3 if it is in the budget. I like the monitor line, but if you have a road to get up to the RTi series on your budget, do so. changing the surrounds can be for down the road. The Mon series for surround will be fine in that set up in the short to moderate term.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Paul.Cox
    Paul.Cox Posts: 12
    edited August 2006
    Thanks for the advise. As a closing comment the local shop let me trial the RTi6 at home. They fell well short of the sound stage I have with the monitor 60s and CS2. Would seem to me I lost depth and size to the front sound stage. The incremental change was limited and in the wrong direction - which I suspect was what the replies above were saying. So will stay with what I have and re aggrange the house to suit.
    Cheers
