Show me your ****(embly), and let me get in your guts baby!
  • halo
    halo Posts: 5,616
    edited July 2006
    Sheng Ya CD-S10 and Kavent CD-731. Identical innards with different faceplates.
  • speakergeek
    speakergeek Posts: 555
    edited July 2006
    This is a great thread.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited July 2006
    Sony's top of the line (MSRP $3,000) CD player from 1998. I bought this out of curiosity because of all the hype about this player. I was very impressed with the heavy duty construction, all copper anti-resonant frame, and ergonomic features. I was not at all impressed on the first listen. I had read reports that the XA7ES needed some modification to reach its full potential.
    The first thing I did was amputate the captive 18 gauge power cord and replace it with an IEC jack. Internally, I ran 12 gauge wire from the IEC jack to the power supply input circuit board. Externally, I connected a Signal Cable MagicPower cable (10 gauge wire). This made a considerable difference in bass definition and impact.
    The next thing I did was replace the wimpy 45 MHz master clock crystal with a precision LClock X03 master clock from LC Audio. The X03 is shown in the 3rd picture in the lower right corner (white arrow) and in the 4th picture in the upper left corner (red arrow). As you can see, the XA7ES is jam packed with circuity. There was only one location available that would accommodate the X03 circuit board: behind the face place. This required a disassembly of the face plate, which really entailed removing all of the external chassis coverings except for the rear plate. The master clock mod provided further improvements in bass definition, detail, and impact, in addition to improved detail in the midrange and treble. It was well worth the $256 spent for the X03.
    This player generates as much heat as some amps. The case temperature (measured with a digital thermometer) reaches 103 degrees after a couple of hours of continuous use.
    Weight: 33 pounds, 1 ounce. Dimensions: 17"W x 5"H x 14-7/8"D.
  • DarqueKnight
    edited July 2006
    From my personal collection of vintage Sony ES components: TA-E90ES from 1996 (MSRP $2,000). Remote controlled, headphone amp/jack, phono stage for MM&MC cartridges. Metal oxide semiconductor (MOS) output stage (something Sony referred to as "MOS Exclusive Design"). Both XLR and RCA inputs and outputs. Inputs for CD, aux, tuner, tape1/DAT/tape2, phono). All discrete ciruitry in the signal path. Glass-epoxy circuit boards, shielded toroidal transformer, Elna SILMIC capacitors, copper screws, anti-resonant construction. An IEC power cable jack was installed. This provided the usual improvements in bass performance.
    Weight: 22 pounds, 11 ounces. Dimensions: 17"W x 4"H x 14-1/4"D.
    The case styling matches the XA7ES CD player and the TA-N90ES power amp.
  • DarqueKnight
    edited July 2006
    From my personal collection of vintage Sony ES components: TA-N90ES from 1996 (MSRP $2,700). It provides 100 watts per channel into 8 ohms, 140 watts per channel into 4 ohms, and is very, very, solidly built. It is the companion amp to the TA-E90ES preamp. It is dual mono and has balanced and single ended inputs, glass-epoxy circuit boards, a shielded toroidal transformer, Elna SILMIC capacitors, copper screws, and anti-resonant construction. The TA-N90ES used metal oxide semiconductors (MOS) in the output stage (something Sony referred to as "MOS Exclusive Design")
    Weight: 48 pounds, 1 ounce. Dimensions: 17"W x 7"H x 17-3/8"D.
  • Mike682
    Mike682 Posts: 2,074
    edited July 2006
    DarqueKnight
    Those are some really nice Sony components.
    Hey guys what is the plural of Sony? Is it Sonys, Sonyies, Sonies?:D
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
    mhardy6647 Posts: 33,043
    edited July 2006
    Mike682 wrote:
    DarqueKnight
    You simply say, "That's a nice Sony he's got there. Those other ones he's got are nice too. All of them." :-P
    They are indeed really nice looking Soneaux, by the way.
  • speakergeek
    edited July 2006
    Mike682 wrote:
    DarqueKnight
    Sonae...:D
    edited July 2006
    that's the ticket!
  • DarqueKnight
    edited July 2006
    From my personal collection of vintage Sony ES components: TA-F808ES from 1998 (MSRP $1,700). It provides 90 watts per channel into 8 ohms, 120 watts per channel into 4 ohms.
    Features a very clean phono section for MM and MC cartridges, heavy weight metal and vibration damping polycarbonate "Gibraltar" chassis, and remote control. The face plate of this amp is extruded anodized aluminum that is 1/8" thick along the front part and and 3/16" thick along the top part. Some Sony ES tuners can be connected to the tuner control port on the rear of the unit and controlled by the amps remote. Sony charges $47 for the cable. Fortunately I found one on eBay on for $20. This TA-F808ES is used with the Sony ST-R730ES tuner shown in the 5th and 6th pictures.
    Weight: 51 pounds, 10 ounces. Dimensions: 17"W x 6-3/4"H x 17-1/4"D.
  • speakergeek
    edited July 2006
    Sony just doesn't make 'em like that any more.
    edited July 2006
    How about this incredible ADC B100 vacuum tube preamp? I stumbled onto this on eBAY for $13. It had a problem with one channel. Long story short... it went back to live with its original designer, Mark Deneen (now the proprietor of Juicy Music and a heck of a guy and a preamp designer/builder).
    Thirteen 6922's in there. Not to mention a pair of Jensen step-up transformers for MC cartridges.
    edited July 2006
    How about a McIntosh C28 preamp? This little guy is hooked up in the basement.
  • schwarcw
    schwarcw Posts: 7,328
    edited July 2006
    Marantz 510M Power amp. 256 wpc @ 8 ohms. Build 1974 - 1978. This was the flagship unit for their power amp. Similiar amplification circuitry was used in their famed 2500 and 2600 receivers. The cooling system was supposedly a NASA concept:rolleyes: The fan can be a little noisy, but the amp can power just about anything. 0.03% THD at rated conditions.
    Carl
    edited July 2006
    Any interest in the innards of a Yamaha R-1000? Not quite up to the CR-xx20 or even CR-xx40 receivers, but not half bad sounding. Plus, the price was right (picked it up at the 'swap pile' at our town transfer station, a/k/a dump).
    SCompRacer Posts: 8,352
    edited July 2006
    Carver TFM-35.
    edited July 2006
    Dodd MLP pre amp.
    edited July 2006
    Howzabout a Soundcraftsmen PE2217 preamp/equalizer? For some reason, I had two of these beasts for a while.
    Nice epoxy PCB's, if nothing else.
  • Early B.
    Early B. Posts: 7,900
    edited July 2006
    Pic of the Buggtussel Somu crossover -- point-to-point, all parts glued onto a small block of wood.
    "God grooves with tubes."
    edited July 2006
    Are those blue things NP electrolytics? If so, shame on them!
  • Early B.
    edited July 2006
    I'd love to upgrade the crossovers, but it would be too much of a hassle. Probably would need to start from scratch.
  • speakergeek
    edited July 2006
    The transformer in this thing is pretty big for a tape deck. It's been in my collection since 1988, and it's still running strong. It's a great tape deck IMO.
    edited July 2006
    Ever seen the inside of a Pioneer CT-F1000 cassette deck? About a decade older than yours...
    Nice photo, BTW!
    edited July 2006
    BTW and FWIW, here're the naughty bits of a Fisher 500C (mine, actually, as re-hab'bed by NOSValves for its original owner).
  • speakergeek
    edited July 2006
    Nice photo, BTW!
    Nice deck! What does that thing weigh?
    edited July 2006
    quite a bit... Hold that thought; I'll dig out the manual and check. :-)
  • speakergeek
    edited July 2006
    No luck finding the manual huh?
    edited July 2006
    Naw... just forgot. I'll check today... it's SATURDAY!
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2006
    I've had a couple of those and they're pretty nice. I like the exposed cassette look on that whole series.
    heiney9 Posts: 25,080
    edited July 2006
    I love the clean look and layout of my Nak pre.
    I was a bit disappointed in the guts of the AMC DAC8. The chassis and face plate are heavy, but the guts are very sparse.
