SDA1 Interconnect Cable Lost
joseph herman
We've just completed our 5th move with our SDA1s...and the Interconnect cable was lost during the move...:mad:
They've been refinshed once, and still work beautifully...How do I find/make a new one..not a Hi-Fi techie, so please give me "Advice For A Dummy".
Thanks,
Thanks,
Post edited by joseph herman on
Hi Joseph!
If you have the blade/blade interconnect cable, you can purchase one from Polk Customer Service for about $30. If you have the pin/blade, just connect a 14 gauge wire into each pin between the two speakers. The blade connection on the pin/blade is there to hold the connector in place and doesn't really have an operational function.Carl -
Carl,
Thanks. I just looked at the back of each speaker...There are two round male side-by-side pin plugs in the top half of the round socket, and one female pin receptacle centered below them on the bottom.
No blade?
Joe -
Does the rear of your SDA1 look like the attached picture?Carl
Exactly like that
Hi Joe!
****! Like F1 said in the Vintage Speaker Forum, this is going to require a little work. Contact Ken Swauger Call 1-800-377-7655 during normal US east coast business hours, Monday - Friday. The cable is not going to be a problem, the connectors might be a little tricky. Ken can give you some guidance. Sorry I can't give you an easier way.
Welcome to the Club Polk Forum! Let us know how it turns out!
CarlCarl -
Thanks everybody
I'll call tomorrow and let you know how it worked out.
