The myths of speakers
Home Theatre
Home Theatre Posts: 469
edited July 2006 in Speakers
Do cables really make a difference?
Do speakers really sound better after a warming up period?
Everything I own burned in the fire!!!!!!!!!!
«13
  • janmike
    janmike Posts: 6,146
    edited July 2006
    According to my ears, YES. My amp gets better after it has warmed up for a while (20 - 30 min).
    Michael ;)
    NORTH of 60°
  • mmcgehee
    mmcgehee Posts: 64
    edited July 2006
    Cables can indeed make a difference.
  • janmike
    edited July 2006
    Here's the deal. Don't listen to other people, check it out for yourself. This is an EXTREMELY controversial topic and "Beauty is in the eye of the beholder" if you catch my drift. I personally beleive that with the proper gear (amp, speakers processor...) cable can make a difference. This post will go on and on and there is only one to check it out - Buy, borrow, beg some cables and find out for yourself. I have only spend modest amounts on IC's and speaker cables (maybe $1000) and it made all the world of difference in my system. Good Luck.
    Michael ;)
    NORTH of 60°
  • Beekyman
    Beekyman Posts: 150
    edited July 2006
    Yes on both accounts!
    All things operate better after a warm-up or break-in period...even humans!
    When I first got into this hobby, I personally thought that wire is wire and you were crazy to spend extra for some fancy packaged wires or interconnects.
    After a little bit of experimentation I found out for myself that good sounding wires and ICs and gear need not be expensive but they do need to to perform to your specs! What sounds awesome to me may be totally flat and lifeless to you! Have fun with experimentation and dont be afraid to try brands that others may disregard...you and your wallet may be pleased in the end!
    2 Channel Rig
    Source 1 - Apple TV
    Source 2 - Parasound D3 Universal Player
    Source 3 - Parasound Tuner T3
    Pre-amp - Parasound HALO P3
    Amplifier - Parasound HALO A21
    Speakers - Martin Logan Vista
    Power Conditioning - Panamax M5100-EX
  • Early B.
    Early B. Posts: 7,900
    edited July 2006
    Yes to both, but the improvements much more discernable on good gear.
    "God grooves with tubes."
    heiney9 Posts: 25,710
    edited July 2006
    Affirmative. Could you be more specific and tell us why you ask? This has been discussed ad-nauseum on this and every other audio board. If you are truely looking for an answer to your query then use the SEARCH function. You could read the posts for days, there are that many.
  • Frank Z
    Frank Z Posts: 5,860
    edited July 2006
    The only correct answer is.....
    Can YOUR ears hear an improvement?
  • audiobliss
    audiobliss Posts: 12,518
    edited July 2006
    Ha, this is a much better 'start a fight' thread. LOL
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • janmike
    edited July 2006
    Dead on the money!
    Michael ;)
    NORTH of 60°
  • Toxis
    Toxis Posts: 5,116
    edited July 2006
    if you A-B two different speaker wires and don't hear a difference, there's a problem elsewhere IMO. Speakers need to break in, not warm up. Equipment warms up.
  • gregure
    gregure Posts: 871
    edited July 2006
    I agree that hearing is believing, but I would find it hard to believe if a person didn't hear the difference.
    It's all a simple matter of physics, undisputable physics at that.
    A source signal can be no better, ever, that the signal itself. Unfortunately, the signal the speaker gets is never as good as what is initially sent out. A better speaker cable can only seek to minimize distortion and degradation of the signal from source to speaker. The better the signal is conducted and shielded, the better it will sound on the speaker end. Better speakers and better amps will help make this difference more apparent, but you should hear a difference of some kind on any level.
    Likewise for the speaker break-in period. The drivers have been constructed and placed within the speaker cabinet, but they haven't had time to settle and stretch. Once a speaker has been played for many hours, the drivers reach their maximum extension, and thus sound a bit clearer, bass a bit deeper, etc.
    Hope that takes some of the mystery out of the myth for you.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
    edited July 2006
    We have had this fight sooo many times.:)
  • johnADA
    johnADA Posts: 98
    edited July 2006
    Anything that moves, gets moved needs a break in period. Things need to seat, settle and so fourth.
    Cables make a difference???, depends. Gauge size and shielding/ insulation, yes, but nothing else.
    What makes good and bad???? Weak minds!!!!
    Copper wire is only produced by a limited number of manufacturers worldwide. If its made in the US, Europe and Japan, its made with the newest method, its good wire. If its 3rd world then pockets of oxygen can be in it and make it bad wire.
    Going super think in insulation/shielding does nothing. Too thin can introduce breaks easier.
    If it uses a NAME, it still uses the same wire, from the same manufacturer, just boughten in low quantities and low quantities cost much more than large. If you bought 100 pounds of copper wire at 12 gauge, you have trucking costs and other costs involved in the price per foot. If you bought 10,000 pounds of the same copper wire, those costs added are spread out further within the weight and the larger commodity on the manufacturing end also does the same thing!!!
    Same wire, same type of shielding and insulaton within reason will have the same performance. Selling small quantities under a AUDIO/VIDEO PHILE NAME just costs more, gives weak minded peace of mind only!!!
    SCompRacer Posts: 9,400
    edited July 2006
    LOL
    What would a strong minded person that speaks in absolutes have to say about cables with passive networks?
  • shack
    shack Posts: 11,154
    edited July 2006
    Yawn..........
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2006
    I wonder if there is some weird pattern to it shack, the lunar cycle? Potted meat on sale at the local grocer?
    edited July 2006
    Full moon on the 4th. I can post one right now, but it could get me banned.
  • johnADA
    johnADA Posts: 98
    edited July 2006
    SCompRacer wrote:
    LOL
    Your talking between changing the cores to create a wanted outcome.
    Were talking a generality that says if 2 things are made the same design way, same materials, it'll perform the same. This applies to your passive network also.
    Names associated with being Audio/Video phile and costing ten times more wont change its performance!!!
    edited July 2006
    OK. Thanks for the explanation.
  • RuSsMaN
    edited July 2006
    Yeah, thank goodness John is here to enlighten us all.
  • audiobliss
    edited July 2006
    Aren't you supposed to be dropping something off at a local UPS drop-off?
    :p:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    edited July 2006
    :p:D
    No nagging! He could be off today. :D
  • johnADA
    johnADA Posts: 98
    edited July 2006
    Somebody has too!!!!!
    If I went by all the crap I see posted on Audio Video forums of how this is soo much better than that and anything along the likes, really dug it, believed it was all so factual,I wouldnt own Polk Speakers, because according to those terms implied by such, there nothing but junk!!!
  • holtzd
    holtzd Posts: 3
    edited July 2006
    Here is a link to an article on Blue Jeans Cable's Web site named "Does Wire Matter?" that is very strait forward.
    http://www.bluejeanscable.com/articles/doeswirematter.htm
    They have several other articles related to cables that are interesting as well.
  • audiobliss
    edited July 2006
    Nice edit, too. :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    F1nut Posts: 52,406
    edited July 2006
    That's one of many mistakes you're making. They're not all the same!
    And this you know because you've tried them all, right!?! :rolleyes:
  • johnADA
    johnADA Posts: 98
    edited July 2006
    I dont need to try them to know that its snake oil, nor waste the money on them.
    Once you get to a certain level of core properties, insulation and shielding you merely just start to begin to pay for things like NAMES.
    You seem to think there are hoards of manufacturers making these cables which is just not even close to the truth. There are few cable makers with hoards of assemblers, and sellers which brand them as their own.
    Blue Jeans which was mentioned is a good example. No where but on their website does it mention who's cable they use. You dont see it on the cable itself, just its type along with shielding info and such. I got there cables because it more than met the basic construction of such cables and the main reason was custom lengths. I dont want 6 foot of cable where 3 1/2 does it right, so I got 3 1/2 foot ones and paid more than I should have, but your fancy dancy Audio/Video phile cables of the same construction carrying $100+ amounts arent gonna make it any better!!
    There is a point where cables wont add, cost cannot be justified, but yet those whom bought them will stand behind to to make peace with themselves justifying the cost.
    I like what I once saw posted and the guy was getting hammered like I am. You stick one high end costed, name branded, piece of cable, between what that company and or you consider as substandard, and honestly say it improved it. Yeah OK!!!
  • shack
    shack Posts: 11,154
    edited July 2006
    I'm guessing sunspots....given the high density of the magnetic fields and such.
    Amen to that. And just in time too.
    F1nut Posts: 52,406
    edited July 2006
    Thanks for proving you don't have a leg to stand on.
    Your thought for the day: Mediocrity.
  • RuSsMaN
    edited July 2006
    Hey Jesse, if they are happy in it, let them soak!
    John, best of luck on your crusade - save us from ourselves and good sound.
