Prayers needed...Time for this to end
    tonyb Posts: 33,065
    edited June 2006
    Prayers sent Vic.Keep us updated.:)
  • jtgranby
    jtgranby Posts: 887
    edited June 2006
  • halo
    halo Posts: 5,616
    edited June 2006
    Went in for another session today and the bppv did not come out!
    We have to start checking some other things that are MS related but it looks like I kicked it's teeth in :D
    Thanks again for the support gang!
  • brettw22
    brettw22 Posts: 7,623
    edited June 2006
    Congrats Vic.
    Exactly what is involved in treating this? Physical techniques? Type of operation?
  • danger boy
    danger boy Posts: 15,722
    edited June 2006
    that is good news... keep up the good work.. hope you improve more and more each day.
    PolkFest 2012, who's going>?
  • halo
    halo Posts: 5,616
    edited June 2006
    Yes its physical. You lay on a therapy table with your head hanging / free floating off the table (the therapist is actually holding your head level at first) while you look up at the ceiling. They turn your head to the right first see if it induces vertigo. They lower your head further and further until the vertigo induces, if it hasn't already done so. Once it (vertigo) starts they hold you steady until it fatigues. Then they continue to slowly lower your head until it's fully extended (pausing if vertigo starts). Repeat the procedure for the left side. Usually only one side will induce vertigo. Then you roll your body to the left until your looking at the ground. They held me there for about 15 seconds and waited to see if the position induced vertigo (it didn't for me). Last thing they do is sit you up and, again, see if vertigo starts (didn't for me in that position either).
    Affter you relax for a minute or two they do it all over again.
    Since it was in my right ear they said I shouldn't sleep / lay on my right side until I came in again.
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2006
    Wow. I've never experience this vertigo or probably anything like it, but having it purposely induced like that until it fatigues itself can be quite stressful, I'd imagine.
    Glad you're doing better with it!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • halo
    halo Posts: 5,616
    edited June 2006
    Past stressful - all out panic :eek:
    Thanks for the support bro :)
  • joeparaski
    joeparaski Posts: 1,865
    edited June 2006
    I told you things were gonna work out. You need to keep a positive outlook on this. Your mind is your best tool.
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • halo
    halo Posts: 5,616
    edited June 2006
    And my worst enemy ;)
  • brettw22
    edited June 2006
    Basically, U2's full of ****........this ain't nothin to sing about. ;)
  • halo
    halo Posts: 5,616
    edited June 2006
    Waaaaaaaaaaaaaaaa! You can say that again!:D
  • schwarcw
    schwarcw Posts: 7,357
    edited June 2006
    Glad to hear some good news about this. I hope you've got this thing whooped! I'll keep pulling for 'ya
    Carl
    heiney9 Posts: 25,396
    edited June 2006
    Good luck Victor. Hopefully you'll be back on your feet in no time.
  • halo
    halo Posts: 5,616
    edited June 2006
    We're working on that too! ;):)
  • halo
    halo Posts: 5,616
    edited June 2006
    Just an update:
    Been through two more rounds of therapy and things went pretty well on the 2nd visit - they couldn't induce vertigo (even though they tried). I'm thinking :cool: problem fixed.
    Before I left I mentioned that they didn't try to induce it in the positions I normally avoid because of the vertigo. Therapist said I should go home and try to induce it myself in those positions I'd been avoiding.
    She and I were under the impression that the problem was fixed. It wasn't :( As soon as I laid flat on my back with my head turned sideways and then I turned my head to look straight at the ceiling BANG! I get vertigo.
    Went in today. Told them what happened. We try to induce the one we "fixed"...nothing :) Then we tried the thing I did at home...you guessed it - vertigo. So we kept repeating the position. Each time we did it the vertigo fatigued more rapidly.
    They are perplexed as to why it's still coming out. :confused: They want me to keep repeating the positions at home until, hopefully, it fatigues permanantly.
    That's where I'm at everybody. Thanks again for all the support :)
  • janmike
    janmike Posts: 6,146
    edited June 2006
    All the best Vic. My brother's had that years ago and all is well today.
    Michael ;)
    NORTH of 60°
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2006
    That's good news, glad to hear it!
  • Schris22
    Schris22 Posts: 983
    edited June 2006
    Hang in there. Good luck!
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • audiobliss
    edited June 2006
    Hope it permanently fatigues soon!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    Follow doctors orders and all should be fine.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • ESavinon
    ESavinon Posts: 3,067
    edited June 2006
    Get well soon. BEST WISHES AND PRAYERS sent.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2006
    I'm sure you will kick it out Victor!
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited June 2006
    Hang in there and keep strong!!
