SVS Power Cord
PSOVLSK
I need a longer power cord for my PB12/2. Any specifications it needs to meet to keep my sub safe? Not as worried about performance as I am about protecting my investment.
Thanks.
Thanks.
Post edited by PSOVLSK on
Wattage/Amperage? Length of cord needed?
At any rate, 14/3 SJ cord will handle 12A easily. Should be more than enough, IMO.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
I put a Signal Cable 12 foot power cable on my SVS 20-39 PC+ and it works fine, actually sound a little better.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Or buy a $4 Volex 14 awg cord the length that you want...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
The stock power cable for the SVS is an 18 guage generic cable. Almost anything you buy would be an improvement. Audio Advisor has PS Audio Power cables on sale for over 50% off. The 1M Prelude is only $49. The Prelude is a 10 guage cable. they also have other larger guage and longer cables on sale. PS Audio is a great product IMO!Carl
polrbehr wrote:Length of cord needed?
Yep, what length are ya' looking for?
Zebra Cables has some really good prices on power cords as well.
SYSTEM
HDTV ..........Sony KP-57WV600
CD / DVD......Sony DVP-C675D
AVR ............Denon 2801
MAINS .........Polk RTi8
CENTER .......Polk CSi5
Surrounds ....Polk FXi3
Sub ............Polk PSW-250
Cables.........Zebra Cables -
Thanks for the replies. I could have/should have been much more specific in asking my question. I'll need about 8 ft to make it work. I guess my real question is: Will the 12 ft computer power cord (18agw/3c) that I have laying around be adequate? By adequate, I really mean will it hurt the sub? I'll probably get something better soon, but if this cable is going to mess up the sub, I'll get something better NOW, before I ever use it. To the best of my knowledge, the power cord will be a question of performance and not safety, but I wanted to make sure.
Thanks again!Things work out best for those who make the best of the way things work out.-John Wooden -
Like Steve said, order a Volex 17605 can't beat it for the money. It's 3 meters (9+ feet) so it's plenty long. And it's shielded which is a plus.steveinaz wrote:Or buy a $4 Volex 14 awg cord the length that you want...
EDIT: there is also a 17604 cord that is 2 meters long, in case you need some upgraded cords for you other equipment.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I doubt it will "hurt" anything.
I checked SVS' website, and as near as I can tell your sub has a 600W amp?
If so, your 18AWG power cord should be fine. I'd still check the plug end in the outlet after several minutes of normal usage and see if it's hot.
FWIW, HomeD has 14/3 SJ , but you'd have to rig up a plug yourself, which is extremely easy to do. You may want to wait til the price of copper has come back to earth, though!So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
PSOVLSK, 18 ga power cords are rated at 10 amperes, i.e. 1200 watts at 120 volts. If your 18 ga cord is in good condition there should be neither a safety nor a performance issue when used for the relatively moderate power requirements of your sub amplifier.
I use the Volex mentioned above on my Outlaw sub. The original cord was a 18 awg 2 conductor. The Volex is a 14 awg 3 conductor, but it works fine. The earth ground will not be in use on the Volex.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
Thanks guys. I'm debating getting the Volex mentioned (thanks for the link) or just keeping what I've got.
I appreciate all the replies!Things work out best for those who make the best of the way things work out.-John Wooden
