Soundbar mounting
newsrus
newsrus Posts: 2
I have decided to mount my soundbar on the wall, but I can't find the two mounting screws that came with it. Does anyone know the specs of the screws so that I can hunt down some replacements in the hardware store?
Post edited by newsrus on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited June 2006
    Hello,
    I believe they are 3mm x 12 mm screws.
    Regards, Ken
  • eeagle
    eeagle Posts: 226
    edited June 2006
    Are you referring to a Polk Surroundbar? As a SDA fan I have been following the good reviews for this speaker system. How do like it? Are you using it with a sub?
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
  • newsrus
    newsrus Posts: 2
    edited June 2006
    It is the Polk soundbar (I figure the screws I need are 9mm.... I have a 3/8 screw which is fractionally too big.... but the nice people at Polk are sending me the correct screws). I'm still playing around with the system, which I'm using with a 10" Polk sub. So far so good.... it's the best solution for my three-walled room, where I have a LCD TV mounted on one of the long walls.
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2006
    Very nice! Welcome to Club Polk Newsrus & Eeagle!
