Soundbar mounting
newsrus
I have decided to mount my soundbar on the wall, but I can't find the two mounting screws that came with it. Does anyone know the specs of the screws so that I can hunt down some replacements in the hardware store?
Post edited by newsrus on
Hello,
I believe they are 3mm x 12 mm screws.
Regards, Ken -
Are you referring to a Polk Surroundbar? As a SDA fan I have been following the good reviews for this speaker system. How do like it? Are you using it with a sub?SDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES -
It is the Polk soundbar (I figure the screws I need are 9mm.... I have a 3/8 screw which is fractionally too big.... but the nice people at Polk are sending me the correct screws). I'm still playing around with the system, which I'm using with a 10" Polk sub. So far so good.... it's the best solution for my three-walled room, where I have a LCD TV mounted on one of the long walls.
Very nice! Welcome to Club Polk Newsrus & Eeagle!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
