Speaker Cable Slack???
wingnut4772
Hey guys. I am getting my new speakers tomorrow and I want to put my surrounds back a bit . I have penty of cable slack on my left surround but for some reason, I can't seem to pull out any more wire from the right even though I have plenty of extra at the equipment hook up location. Should I be able to tug on this and get some movement or did my installer do something tricky?
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
If you have enough to hookup the speaker I wouldn't worry about it.
It's a stretch actually. It's gonna depend on where the hook ups are on the Von Schweikert surrounds. I can't seem to find a picture of the rear of those babies. (TS-150).Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
grats on the new speakers
Home Theater In Progress
Samsung 4272
Denon 3910 Universal Player
Anthem AVM-20
Anthem Statement A5
Fronts LSI-25
Center LSI-C
Surround LSI-FX
Getting closer to complete!:D -
Thanks ...:D but it remains to be seen if I prefer them to the LSis ....we will see;)Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Ok, usually most electricians will staple the wire or if they're smart, cable-tie the wire to a staple. they should have left a bunch of slack, but that's obviously not the case. You might be able to get some more slack by reaching into the wall/ ceiling, finding the first staple and prying it loose. Otherwise, you're SOL.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
just looked at your system pics... not looking good. Your best bet might be to take out one of those ceiling cans & seeing if you can reach the wire/ feel what the problem is.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Well I think I will just have enough. I just found out the VS speakers have their speaker hook ups in the middle and the LSiFxs are to the far side making it a stretch so I will have about an inch to spare.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Bout an inch to spare................glad to finally hear a woman say that.:D
Hope the VS is a good line for you Darla! Keep us posted!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Ha!:D Will do.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
If they just ran the wire without attaching it to anything (like the staple / zap strap method) it's possible it looped and then got stuck at the hole. This happened to me when we ran cable up to my room. Maybe try pushing it back into the wall for as much slack inside as possible and jiggling it a little? It's a long shot, but maybe worth a try if you want to have a little more slack than an inch or two...
