turn on off order?
higgins79
higgins79 Posts: 72
i have the sequential tuirn off on my power center but i usually just leave it on (is that bad?) if i do leave it on what order should i tune the amp and avr off and on in?
TV ................Sony kdl52xbr4
Reciever ........Denon AVR 988
Amp -............Monster MPA 2250
Bluray............Sony PS3 (80gig)
Hddvd............xbox 360 Hddvd
Power centers.Monster 3600II & 2600II & 1600 x2
Voltage..........Monster AVS 2000
Fronts ...........polk Rti12s
Center ..........polk Csi5
Rears.............polk Fxi5s
Sub ..............Infinity PS12
cables............Monster / DIY
Video games...XBOX 360 / Wii
Post edited by higgins79 on
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2006
    I've never bothered with "turn-on" sequences, though I think for tubed equipment it may be a different story...maybe a polkie tube-head will chime in with more info.
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    I have my amp turn on last after a 15 second delay.
    It just helps prevent spikes or surges when everything turns on at the same time.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • beardog03
    beardog03 Posts: 5,550
    edited May 2006
    I always do source,pre,amp with my tube gear..
    Reversed order to shut down
    SS gear...not sure it matters, but I do the same just because
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • halo
    halo Posts: 5,616
    edited May 2006
    Same here for tube gear. Tube amp before tube pre is a bad idear in my experience.
    I'm with you on th SS gear - I really don't think it matters but I follow the tube gear sequence anyway.
  • steveinaz
    edited May 2006
    My wife gets a kick out of the family room lights dimming when I power up the amp.
  • wlrandall
    wlrandall Posts: 440
    edited May 2006
    Amps on last, off first for me.
  • SuperDave
    SuperDave Posts: 168
    edited June 2006
    "My wife gets a kick out of the family room lights dimming when I power up the amp."
    Cool mine does that too.
    Amp on last off first like above.
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • schwarcw
    schwarcw Posts: 7,358
    edited June 2006
    Ditto for me, this is home the Monster Power centers do it.
    Carl
  • ward91
    ward91 Posts: 338
    edited June 2006
    my amp stays on standby coz it doesnt get used alot but my avr stays on all the time
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • MrNightly
    MrNightly Posts: 3,370
    edited June 2006
    I always turn my AVR on first... oh wait.. I only have an AVR.
    Oh well, someday I'll be able to worry about which piece to turn on first... ;)
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
  • higgins79
    higgins79 Posts: 72
    edited June 2006
    sorry i never said thanks for the replies. avr on first and of last got it. thanks again.
    heiney9 Posts: 25,412
    edited June 2006
    Chiming in a bit late. It really depends if you amplifier has a delay (muting) circuit (usually a relay). If it does, it really doesn't matter the switching order. If it doesn't then amp on last; amp off first.
    My turn on sequence is pre-amp, dac, cdp, amp.
    My turn off sequence is amp, cdp, dac and then pre-amp after the caps have discharged in the amp.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2006
    Of course if your pre has a mute switch it should be used first, now is anyone confused..............
    Your trying to prevent pops and the caps from emptying out the last of their energy through the speakers. Doing it wrong can damage your system.
    RT1
