Internal Speaker Wire
Raife has already been down this road. In his updating the SRS thread.
"Prior to modifying my SDA 1B speakers in 1990, I called Polk and asked about the benefits of particular parts upgrades. The engineer I spoke with, Chris, said that there would be no benefit, audible or otherwise, from changing the internal wiring because the distances were so short and the stock wiring was of the appropriate gauge.
I replaced all the wiring anyway just to hear for myself. I used 12 gauge monster cable and soldered the wires directly to the drivers. Just as Chris predicted, there was no audible improvement. I switched back to the stock cables with the clips".polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
I didn't hear any improvement or difference in my experiment, but someone else with different wire, different speakers, different equipment, and different ears might.
Some people claim they can hear a difference and/or improvement between different types of binding posts. I've never heard such a difference and/or improvement. But someone else.......Proud and loyal citizen of the Digital Domain and Solid State Country! -
Makes no sense that it wouldn't make a audiable difference, But i tell ya.. some people on here i just take thier word that they know what they are talking about,
I guess it kinda gets down to, specifics... what about the wire in your amp, the wire in the cd player, and so on... better off left alone and not to worry about it i guess. havent worried about it up to this point.
I still can't see spending multi hundreds on IC's
But i wont be rewireing my speakers or amps either in the near future
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
faster100 wrote:Makes no sense that it wouldn't make a audiable difference, But i tell ya.. some people on here i just take thier word that they know what they are talking about,
Just keep stirring the pot! -
Look a squirrel.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Drumingman wrote:Just keep stirring the pot!
what are you talking about? you started the topicMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Zero wrote:I don't understand how a special 1-8ft power cord will be able to improve anything when its tapping incredibly dirty power through crummy house-hold wiring on an average circuit. Forget the fact that most standard equipment trace the signal from the IEC to the transformer via: Circuit board, instead of wired directly to the transformer. Wouldn't the weak point be at the contact point? Doesn't this also apply to speaker wire?
And roun' and roun' we go.,
BINGO! We have a winner!
I replaced the power cord on my Jolida CD player, could not hear a difference, even on some VERY revealing speakers and amps.
Maybe I just don't have a pair of "golden ears" like some "audiophiles", but at least I can admit it.
So it is not worth it to replace my internal speaker wire on some RTi10's with 12 gauge right?Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
The only way for you to know is to try it.Political Correctness'.........defined
President of Club Polk -
I think what it comes down to at this level of audio tweaking is a sum of several parts making an audible difference. If you are going to use a mediocre receiver, mediocre source, etc. a tweak like changing the guage of the internal wire isn't going be worth the effort. Now if you are using a great amp, great source, proper IC's and speaker wire and have set your system up properly (placement) for the best possible performance then *perhaps* tweaking the speaker internals might make a difference.
Only way to know is to try it.
It's really like tweaking a combustion engine. Adding a bigger throttle body won't nec make a difference. But, add a larger exhaust, higher performance camshaft, larger intake, etc. and then the sum of all those parts is realized."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I kind of disagree to a point.. I don't think you always need high end gear to notice improvments. Now of course if you have a cheap rack system maybe but average to good gear can notice a change.. Some people like me just can't always notice the change, like IC's, speaker wire and power cords.
I certainly don't have golden ears, But you do need to just try to see what ya hear.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
F1nut wrote:And we all know how your mind works.
or doesn't work...as the case may be.
My opinion is this: Would upgrading the internal wire be a good thing? Sure. Every manufacturer has to make a decision about things like that. However, there are also some practical concerns such as space as well.
However, what makes no sense is the attitude that if you aren't going to upgrade EVERY inch of wire than it makes no sense to upgrade ANY of the wire. If you apply the same logic, why move past a clock radio if you can't move right into the Wilson Grand Slamm system?
I also subscribe to Jesse's point of bringing the signal to the crossover is more signifigant.
without the jackass comments, I actually have since decided and agree.. going overboard with "well what about this wire" is well, Overboard.. Because then you have to evaluate every piece of wire in the system.
Its like asking how the Universe was created? who cares were here now..
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
