Pioneer Elite VSX-74TXVI, Sunfire 225x5, entire LSi series.
PolkPioneer
PolkPioneer Posts: 6
edited June 2006 in Troubleshooting
Dear Sirs,
I have the following set:
- Receiver: Pioneer Elite VSX-74TXVI
- Amplifier: Sunfire 225x5
- Front: LSi25
- Center: LSiC
- Subwoofer: PSW1000
- Surround: LSiFX
At first I did not have the Sunfire amplifier.
The Pioneer volume goes from -80dB to +12dB, at the maximum, depending
on the mode, sometimes it stops at +2dB.
I could only get audible sound from the system at around -10dB and
reasonable audible level at around -5dB and even then, it was not loud
enough to disturb two people's conversation.
Then I read in the Pioneer's manual that it handles 8 or 6 OHMs speakers
and the LSi are 4 OHMs.
I bought the Sunfire amplifier that outputs the 5 channels, 225WPC at
8 OHMs, 450WPC at 4 OHMs and 900WPC at 2 OHMs (limited time basis).
After hooking up the Sunfire, to my surprise, the system sound basically
the same.
Based on your experience, what do you think it is happening?
Thank you in advance for your help.
Best regards,
Marcos
Post edited by PolkPioneer on
  • masanz1
    masanz1 Posts: 511
    edited May 2006
    It's all junk is the problem, I'll be glad to take it off your hands though.:D
    Welcome to the club, sound like some connection isn't right. Maybe a setting in the unit. Almost sounds like you're in mute
    Matthew
    Sometimes the road less traveled is less traveled for a reason
    HT
    Yamaha RX-V2500
    CS400-Center
    SDA 1A-Mains
    RT20-Surround
    None right now-Rears
    SVS 20-39PCi
    Infocus IN72
  • PolkPioneer
    edited May 2006
    Thank you masanz1.
    For a second I thought you were serious about the "junk" statement.
    You almost gave me a heart attack.
    Last night, I almost read the entire Pioneer manual and there was one
    item that for some reason was set on my receiver, "analog attenuator"
    (this controls the analog signal strength from an input to the receiver
    so that it does not get distorted).
    I turned the system, set the "ATT" to off and the difference was noted.
    Now I start having audible sound at around -30dB, instead of the -20dB.
    It made a substantial improvement, but I was expecting a little more
    and after speaking with a co-worker, he told me to play with the wires
    to separate the low from the high frequencies and get the lows from
    the PSW1000 and then to the LSi25.
    I will try it tonight.
    Thank you for your help,
    Marcos
  • miguel rios
    miguel rios Posts: 4
    edited May 2006
    Hi Marcos:
    If I understand OK, you have your speakers connected to the receiver through the amplifier. Now, from where in the receiver are you taking the signals and feeding them to the amplifier?. An amplifier should take around 1 volt to deliver full power, so if you are feeding much less than 1 volt from the receiver, the amplifier will not be happy.
    Miguel
    Dear Sirs,
    - Front: LSi25
    - Center: LSiC
    - Surround: LSiFX
    the same.
    Best regards,
    Marcos
  • kingkip
    kingkip Posts: 401
    edited May 2006
    How do you have your speaks hooked up? Do you have the amp out to the sub and then to the speakers? If so I would use the LFE out to the sub and run the amp straight to the speaks.
    Just a WAG but maybe something there.
    There are two ways to argue with women. Both of them are wrong.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2006
    Try hitting the "Mute" button.
    Welcome to the forum.
    I would actually suggest you simplify everything first and work forward. Try the Pioneer AVR with only the LSi25 or even the FX as L&R main speakers. If you have settings on the AVR, write them down and reset the AVR to factory default. Do they sound different?
  • PolkPioneer
    edited May 2006
    Hello Miguel,
    Thank you for your reply.
    To answer your question, I am using my receiver as a pre-amp,
    connecting it to the amplifier thru the "pre-out" output RCA connectors
    in the receiver.
    Miguel, as I mentioned above, the "analog attenuator" receiver setting
    was on and after I turned it off, it made a substantial improvement in
    the volume.
    I guess after spending a considerable amount of money, I was expecting
    not only undistorted, high fidelity, but also very loud sound -- I had the
    first two, but not the last one.
    After reading several articles in magazines and in the internet, I decided
    to keep this system for the Home Theater and to buy another one to
    listen to music only, in stereo.
    The new system will consist of the same Pioneer Elite VSX-74TXVI and
    a pair of Klipsch RF-83 (100dB sensitivity at 8 ohms).
    Marcos
  • PolkPioneer
    edited May 2006
    Thank you for your reply Dorokusai,
    I actually had the Polk speakers connected directly thru the
    Pioneer receiver.
    After not being happy at all with the loudness, I decided to
    buy the Sunfire amplifier.
    As I wrote to Miguel, I decided to keep this system for the
    Home Theater and to buy another one for music only with
    the same receiver and a pair of Klipsch RF-83 (100dB sensitivity
    at 8 ohms) -- this time I would expect to hear it loud enough.
    Marcos
  • PolkPioneer
    edited May 2006
    Thank you for your reply Kingkip,
    >to the speaks.
    I have the "pre-out" RCA outputs from the receiver connected
    to the amplifier and from the amplifier to the speakers.
    I am using the "sub-out" RCA output to the subwoofer.
    Therefore, I am not using the connection from the subwoofer
    to the speakers.
    Marcos
  • scottnbnj
    scottnbnj Posts: 709
    edited May 2006
    welcome PolkPioneer, i don't know much about all this multi-channel voodoo, but,..
    does this happen with all sources? could it be something like the volume or channel trim settings in your player?
    i think everyone's right in looking for a setting or connection problems somewhere... unless something is broken. it's hard to believe that you don't have enough power, but you don't hear distortion, compression or something bad happen before running out of juice.
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    With that amp you should get plenty of power.
    Mine is 200wpc @8 and I can not stay in the room past -10db for fear of bleeding ears.
    Something is wrong and I suspect it is a setting.
    I am not familiar with the Pioneer line but that is my thought also.
    What kind of RCA's are you using?
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
    tonyb Posts: 32,911
    edited May 2006
    Does your AVR have 2 sets of pre-outs? Mine did and that was the exact problem I had.Some AVR'S have a sep. set for SACD OR DVD-AUDIO,
    check it out
  • PolkPioneer
    edited June 2006
    Thank you all,
    I decided to send an e-mail to Pioneer customer's service
    and they promptly replied to me saying that for my case it is
    best to call the 800 number and speak with a technician.
    I did it, explained the problem that I was having with
    low volume and he told me to manually change the
    equalization of each channel.
    The equalization is based on Decibels and it ranges
    from -10db to +10dB.
    When I bought the Pioneer, I had the equalization
    done by their MCACC system, where you place a
    microphone in a location of the room where you
    would listen most of the time.
    When I went to change it manually -- the front speakers
    were set at -2.5dB!!!!!!!! No wonder I had almost no
    sound coming from them.
    I gladly increased it 0.5dB at a time, to the maximum
    of +10dB!!!!!!!!!
    When I played the same music back again, it was like I was
    in a night club, literally.
    My ears started hurting and I had to turned it down.
    Now I am very happy.
    My ears are still echoing inside.......
    That was the kind of sound I was expecting to hear!!!
    Thank you all for your help -- I sincerely appreciated,
    Marcos
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    Good to hear it.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • masanz1
    masanz1 Posts: 511
    edited June 2006
    thanks for the followup
    Matthew
    HT
    Yamaha RX-V2500
    CS400-Center
    SDA 1A-Mains
    RT20-Surround
    SVS 20-39PCi
    Infocus IN72
  • aaharvel
    aaharvel Posts: 4,490
    edited June 2006
    of +10dB!!!!!!!!!
    quick question- is it a good idea to have your receiver at +10db. on all speakers? Mine all sound fine set to 0db, but from a volume perspective, If I turn everything up to +10db, would it damage the receiver or speakers? (i have a separate amp, the receiver's just the processor)
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2006
    Hi PolkPioneer. Congrats on figuring out the problem. However I totally agree with what Aaharvel has said. You should get yourself a SPL meter from Radio Shack & manually set the levels using that to set to reference levels. Until then reset the mains to 0db and maybe bump up the center channel to +1 or +2db. (So that dialog comes in clearly)
    Welcome to Club Polk.
  • speakergeek
    speakergeek Posts: 555
    edited June 2006
    If it's like the VSX-1015TX, which I have, it will subtract the speaker settings from the maximum volume. Mine will go to +12 on the dial with the speakers all set a 0 db. Anything above 0 gets subtracted from the master volume setting. So if I was at +2 speaker setting, the master volume would only go to + 10. So he would only be able to hit +2 on the master volume.
