How to protect electronics against lightning?
crazy
crazy Posts: 443
edited May 2006 in Electronics
It's raining cats & dogs here along with lots of lightning - so I'm wondering how to protect "my precious" electronics from lightning?
Is switching off the surge-protector switch sufficient or should the electronics be unplugged?
Distant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes)
Post edited by crazy on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2006
    Surges are one thing and can be protected against, but lightning is no surge.
    Unplug power, cable/sat and remove grounds, to be safe.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited May 2006
    Unplug it and disconnect the antennas, Nothing will divert a direct strike. The electromagnetic field will cook the chips.
  • dorokusai
    dorokusai Posts: 25,622
    edited May 2006
    I use a hobo shackled to a 20 foot ground rod on the side of my house.
  • madmax
    madmax Posts: 12,434
    edited May 2006
    And when I get loose I'm reporting you to the authorities. :eek:
    madmax
    Vinyl, the final frontier...
  • shack
    shack Posts: 11,154
    edited May 2006
    For the PC police around here you should probably refer to your human lightning rod as an occasionally mobile homeless individual.
  • kingkip
    kingkip Posts: 401
    edited May 2006
    It's funny because he said hobo.
    There are two ways to argue with women. Both of them are wrong.
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2006
    WAAAAAAAAAAA!!!! Leave it to Mark!:eek: :D:D:D
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2006
    It's not so funny once you've smelled burnt hobo.
    Unplug it.
  • drew spelts
    drew spelts Posts: 310
    edited May 2006
    It's their singed Tom Selick chest hair that stinks so bad.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
  • dorokusai
    edited May 2006
    I would say the urine soaked trousers sure don't help much.
  • polrbehr
    polrbehr Posts: 2,864
    edited May 2006
    www.deltasurgeprotectors.com
    I have installed these many times.
    If you have any fears of working in a live panel, consult an electrician.
  • labrat
    labrat Posts: 120
    edited May 2006
    It seems to me that any voltage strong enough to jump hundreds of feet through the air (lightning) isn't going to be stopped by less than an inch gap in any switch. You are much better off unplugging the power and cable/sat/antenna connections to your components.
    Just my .02
    Scott
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2006
    Having fixed many electronic devices damaged by Lightning / some being so damaged it was NFR "Not Feasible to Repair". Phone lines are bad coming into house, Antenna or Cable is bad so disconnect these. Switches are like capacitors in lightning strikes so being off doesn't help any, Being a power switch in device, Circuit breaker, or wall switch. So when in fear disconnect all power / Antenna / phone line.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • I-SIG
    I-SIG Posts: 2,243
    edited May 2006
    You really need to watch your phone and CATV grounding. They can be very lax especially in comparison to what the electric utility does.
    Induced voltage & current from a lightning strike near a utility line is much more common than a direct hit. Voltage climbs at phenomenal rates, say up to 68kv in about 20 micro-seconds. (yes micro, not milli.) At this point most lightning arrestors are just starting to bleed that overvoltage off at their full strength so voltage can continue to rise considerably. Although most primary in the US is in the neighborhood of 12.47kV properly specified systems can withstand a BIL (basic impulse insulation level) of 250-350kV. I seriously doubt any consumer electronics could handle the 68kV much less 350kV.
    So, when in doubt, unplug everything.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • unc2701
    unc2701 Posts: 3,587
    edited May 2006
    With the level of gear you've got (IIRC), you might want to look at Torus Power:
    http://toruspower.com
    They're certified to take a 18000kva hit 1,000 times without failing, plus output balanced power. Yes, they're expensive, but so is replacing all your gear.
    edit: fixed link
    Backburner:Krell KAV-300i
  • disneyjoe7
    edited May 2006
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    :eek: Yikes :eek:
    Good lord thats alot of money.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • unc2701
    edited May 2006
    Yep, my gear isn't worth enough to justify it... but they're not cheap to build; check out the size of the power supply:
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    I have a hard time believing that does not get hot.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • disneyjoe7
    edited May 2006
    Now I have heard of dedicated 20 amps outlets, but never heard or seen a "Dryer" outlet for audio. HOLLY ****
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • unc2701
    edited May 2006
    i have a hard time believing it doesn't give you cancer. It looks like it could bend forks from across the room. My buddy has one of these in stock (the 20 amp x3) and we cracked open the box, but decided we'd throw out our backs just trying to get it any further. We'll probably demo it once I get into my new house.
  • drew spelts
    edited May 2006
    Thats GD rediculous. I believe that they do not produce much heat. The only reason these do not produce heat is because they use AC current. If everything were DC then they would need moving parts and that would procude heat. We just learned about this kind of stuff in radiological science classes.
    RTi10's Up Front
    CSi5 Center
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2006
    "Lock the door. And hope they don't have blasters."
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Beekyman
    Beekyman Posts: 150
    edited May 2006
    Just remember..."One point Twenty-One GIGAWATTS !!" - Dr. Emmit Brown in Back To The Future.
    Nothing can stop the mighty hammer of Thor! Unplug your gear just to be safe!
    2 Channel Rig
    Source 1 - Apple TV
    Source 2 - Parasound D3 Universal Player
    Source 3 - Parasound Tuner T3
    Pre-amp - Parasound HALO P3
    Amplifier - Parasound HALO A21
    Speakers - Martin Logan Vista
    Power Conditioning - Panamax M5100-EX
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    I knew this would come out.
    I could not remember the exact quote or I would have done it. :D
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
