How to protect electronics against lightning?
crazy
It's raining cats & dogs here along with lots of lightning - so I'm wondering how to protect "my precious" electronics from lightning?
Is switching off the surge-protector switch sufficient or should the electronics be unplugged?
Distant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes)
Post edited by crazy on
Surges are one thing and can be protected against, but lightning is no surge.
Unplug power, cable/sat and remove grounds, to be safe.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Unplug it and disconnect the antennas, Nothing will divert a direct strike. The electromagnetic field will cook the chips.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
I use a hobo shackled to a 20 foot ground rod on the side of my house.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
dorokusai wrote:I use a hobo shackled to a 20 foot ground rod on the side of my house.
And when I get loose I'm reporting you to the authorities. :eek:
For the PC police around here you should probably refer to your human lightning rod as an occasionally mobile homeless individual."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
It's funny because he said hobo.There are two ways to argue with women. Both of them are wrong. -
WAAAAAAAAAAA!!!! Leave it to Mark!:eek:
Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
It's not so funny once you've smelled burnt hobo.
Unplug it.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
It's their singed Tom Selick chest hair that stinks so bad.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
I would say the urine soaked trousers sure don't help much.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
www.deltasurgeprotectors.com
I have installed these many times.
If you have any fears of working in a live panel, consult an electrician.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
It seems to me that any voltage strong enough to jump hundreds of feet through the air (lightning) isn't going to be stopped by less than an inch gap in any switch. You are much better off unplugging the power and cable/sat/antenna connections to your components.
Just my .02
Scott -
Having fixed many electronic devices damaged by Lightning / some being so damaged it was NFR "Not Feasible to Repair". Phone lines are bad coming into house, Antenna or Cable is bad so disconnect these. Switches are like capacitors in lightning strikes so being off doesn't help any, Being a power switch in device, Circuit breaker, or wall switch. So when in fear disconnect all power / Antenna / phone line.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
You really need to watch your phone and CATV grounding. They can be very lax especially in comparison to what the electric utility does.
Induced voltage & current from a lightning strike near a utility line is much more common than a direct hit. Voltage climbs at phenomenal rates, say up to 68kv in about 20 micro-seconds. (yes micro, not milli.) At this point most lightning arrestors are just starting to bleed that overvoltage off at their full strength so voltage can continue to rise considerably. Although most primary in the US is in the neighborhood of 12.47kV properly specified systems can withstand a BIL (basic impulse insulation level) of 250-350kV. I seriously doubt any consumer electronics could handle the 68kV much less 350kV.
So, when in doubt, unplug everything.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
With the level of gear you've got (IIRC), you might want to look at Torus Power:
http://toruspower.com
They're certified to take a 18000kva hit 1,000 times without failing, plus output balanced power. Yes, they're expensive, but so is replacing all your gear.
edit: fixed linkGallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
try this link
http://www.toruspower.com/
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
:eek: Yikes :eek:
Good lord thats alot of money.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Yep, my gear isn't worth enough to justify it... but they're not cheap to build; check out the size of the power supply:
I have a hard time believing that does not get hot.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Now I have heard of dedicated 20 amps outlets, but never heard or seen a "Dryer" outlet for audio. HOLLY ****
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
i have a hard time believing it doesn't give you cancer. It looks like it could bend forks from across the room. My buddy has one of these in stock (the 20 amp x3) and we cracked open the box, but decided we'd throw out our backs just trying to get it any further. We'll probably demo it once I get into my new house.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Thats GD rediculous. I believe that they do not produce much heat. The only reason these do not produce heat is because they use AC current. If everything were DC then they would need moving parts and that would procude heat. We just learned about this kind of stuff in radiological science classes.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
Just remember..."One point Twenty-One GIGAWATTS !!" - Dr. Emmit Brown in Back To The Future.
Nothing can stop the mighty hammer of Thor! Unplug your gear just to be safe!2 Channel Rig
Source 1 - Apple TV
Source 2 - Parasound D3 Universal Player
Source 3 - Parasound Tuner T3
Pre-amp - Parasound HALO P3
Amplifier - Parasound HALO A21
Speakers - Martin Logan Vista
Power Conditioning - Panamax M5100-EX -
Beekyman wrote:Just remember..."One point Twenty-One GIGAWATTS !!" - Dr. Emmit Brown in Back To The Future.
I knew this would come out.
I could not remember the exact quote or I would have done it.
Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
