Monitor 50 vs. Monitor 30
Hey gang,
Along side with upgrading my sub, I will be upgrading my current front speakers, the Monitor 30s', with the floorstanding Monitor 50s'. Will I notice a difference in clarity, range, field? Also, would I even need a subwoofer with the 50s' (I've heard some people do, some don't.)? Any help would be greatly appreciated! Thanks!
Oh, and two more things, my reciever puts out 110W per channel; would I need a seperate amp to power these baby's? And lastly, these will be going on carpeted floors. Are these very easy to tip over? Like if one of my cats, or my future child were to accidentally love-tap these, will these fall over? Thanks!
-Tom
-Tom
My Living Room 3.1 config:
Toshiba 40RV525U
Receiver: Onkyo TX-NR609
Center channel: Polk CS1
Front L/R: Paradigm Reference Studio 20
Subwoofer: Velodyne DPS-10
Rears: None
My Computer setup
Klipsch Pro Media 2.1 THX
Toshiba 40RV525U
Rears: None
My Computer setup
Anyone?My Living Room 3.1 config:
Toshiba 40RV525U
Rears: None
My Computer setup
Klipsch Pro Media 2.1 THX -
dont know about clarity since they do use the same tweeters right.. but it should sound fuller..
frdranger wrote:Hey gang,
the monitor 50s have much better bass response and cleaner highs. towers usually sound much better than bookshelves.frdranger wrote:Also, would I even need a subwoofer with the 50s' (I've heard some people do, some don't.)?
you need a sub, the 50s will hit much lower than the 30s but nothing like a powered sub.frdranger wrote:would I need a seperate amp to power these baby's?
You can get a seperate amp if you want to, but not necessary with these entry level speakers.frdranger wrote:Are these very easy to tip over?
umm, its possible if hit hard enough...AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
I listened to the M50's a bunch of times, I really liked the 50's when I listened to them side-to-side with a set of 40's. Sub will really be required to get that bottom end, with my 70's the Sub is still a great addin.
So/so feeling on the tipping, they are a tall skinny design... Would not take much effort to tip them over... lolRockin' In My House
Pioneer 50 inch Plasma TV
Denon AVR-3806
Denon DVD-1930ci
Polk Montor 70's
Polk PSW-12
Polk CS2
Polk Monitor 40's
Sirius Satellite Radio, Monster 3500MKII -
I would spend an extra 200 and get the M 60's.Everything I own burned in the fire!!!!!!!!!!
Thank's for all your replies! I went ahead and purchased a pair of M50s' and they sound phenomonal!! Was having a little difficulty because the system kept shorting out. But got it fixed and it sounds beautiful! Thanks for all of your inputs and suggestions!
Toshiba 40RV525U
Rears: None
My Computer setup
Compare the M 50s against the M 60s, no question, the 60s sound much better.NOT MUCH, BUT IT'S ALL MINE!
SONY 60" SXRD (HDTV)
Explorer 8300HD (HD-DVR CABLE BOX)
Toshiba SD-3750 (DVD PLAYER)
Onkyo TX-SR702 (RECEIVER)
Polk Monitor 60 (FRONTS)
Polk CS2 (CENTER)
Polk Monitor 30 (SIDE SURROUNDS)
Polk Monitor 30 (REAR SURROUNDS)
Mirage Omni S-12 (SUBWOOFER)
Tripplite HT 1000UPS (POWER PROTECTION)
Omnimount (CENTER CHANNEL SHELF)
B-Tech BT34 (SURROUND SPEAKER MOUNTS) -
$138, then $149 (open box).
Now they're back to $25X.
Keep an eye on www.onecall.com, the 60's a good speaker at the cheap price.
Onecall also has the Athena AS-P4000 on sale for $149.97
http://www.onecall.com/ProductSearch.aspx?bid=458&sHist=12-110%2c6-458 :eek:
Recommend you get it from Amazon.com (free shipping).
LATE EDIT: Monitor 60's are back for $134.60 each, open box, limit one.
http://www.onecall.com/ProductSearch.aspx?bid=422&sHist=12-110%2c6-422&Page=-1&Sort=lowPriceSal Palooza -
FicmanS wrote:Sub will really be required to get that bottom end, with my 70's the Sub is still a great addin.
Agreed. Even the 70s dont have much bass, but with a velodyne that's not really a problem
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
BjornB17 wrote:Agreed. Even the 70s dont have much bass, but with a velodyne that's not really a problem
Jeez Bjorn...
where've you been?:DI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
zombie boy 2000 wrote:Jeez Bjorn...
LOL... i figured nobody would notice my departure. I've been busying myself working on a model plane which has been taking up lots of time
but i came here and saw a thread about the monitors and though i could help
that's really good stuff:)
glad to have you backI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
aaharvel wrote:Huh?
bigger speakers usually sound better, wants wrong. I know that just say an lsi bookshelf will sound better than a monitor tower, but im comparing apples and oranges here. in the same price range, bigger speakers usually sound better, aren't I right?AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
i guess it just depends on the ears. To mine, the lsi9 is the best of the series. I just like the sound of a good bookshelf speaker over the tower equivalent. Just me.
aaharvel wrote:i guess it just depends on the ears. To mine, the lsi9 is the best of the series. I just like the sound of a good bookshelf speaker over the tower equivalent. Just me.
well, i don't have much to compare to. The only polk speakers I have heard is the monitor series and RTI towers... When it comes to the monitor series, I think the 50s and 60s sound much better then the monitor 40s and 30s. but in other series models, maybe you're right.AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Gamertag: kovster27
