Adcom 565 mono block
StarlightWk
StarlightWk Posts: 33
edited May 2006 in Vintage Speakers
Hi guys,
I am planning to buy a Adcom gfa 565 mono power amp to be use on
Polk SDA SRS . Is there any problem with the common ground issue on
this 565 mono block on the SDA SRS ? Appreciate this valuable info asap
b4 this 565 is gone , thanks .
Post edited by StarlightWk on
    F1nut Posts: 51,715
    edited May 2006
    Do you have another one to use or what?
  • StarlightWk
    edited May 2006
    Hi F1nut,
    I intend to buy the adcom 565 mono block , and shift the existing 555mk11
    for H.T. useage. Is there any common issue on this 565 that i intend to buy ?
    thanks in advance .
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2006
    Starlight, what Uncle Jesse is trying to say, is unless you plan on listening to a SINGLE SDA (mono), you're one amp channel short of a great listening experience.
  • StarlightWk
    edited May 2006
    Hi Russman,
    Of course the 565 comes in a pair , please enlighten me if I can drive the
    SDA SRS without the common ground issue , thanks .
    F1nut Posts: 51,715
    edited May 2006
    They don't have to come in pairs and you used a singular description in your comments. The English language is a finely honed tool and when used correctly is very helpful to all involved.
    Anyway, there are two circumstances when you can use mono block amps with SDA SRS speakers. One is if your serial numbers are above 5001 on both speakers. If so, you can use the special AI-1 interconnect cable, which you'll have to make as it's no longer sold. The other is if you can tie the negative outputs of the amps together to create a common ground. You'll have to check with Adcom to see if that can be done with those amps.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2006
    StarlightWk,
    The GFA-565 monoblocks will work great with the SRS's. I have a pair of these amps as well as SRS's. You will need to do the following things:
    1. Connect the negative binding post terminals of each amp together with some good quality wire.
    2. Connect the chassis of each amp together with some good quality wire that is the same size gauge as the wire connecting the negative binding post terminals. The chassis screws make good connection points. A good idea is to solder each end of the wire to a thin metal washer that has a soldering tab.
  • StarlightWk
    edited May 2006
    Thanks DarqueKnight, will follow as per your instructions. Better go snap up the mono blocks b4 there are gone . Its hard to come by these mono blocks in by
    area. Cheers !
  • StarlightWk
    edited May 2006
    Thanks to F1nut too.
  • RuSsMaN
    edited May 2006
    What about me?
    High five!
    F1nut Posts: 51,715
    edited May 2006
    Thanks Russ.
  • StarlightWk
    edited May 2006
    Last but not least RUSS the Man, Thanksssssssss
