Adcom 565 mono block
StarlightWk
Hi guys,
I am planning to buy a Adcom gfa 565 mono power amp to be use on
Polk SDA SRS . Is there any problem with the common ground issue on
this 565 mono block on the SDA SRS ? Appreciate this valuable info asap
b4 this 565 is gone , thanks .
Do you have another one to use or what?
Hi F1nut,
I intend to buy the adcom 565 mono block , and shift the existing 555mk11
for H.T. useage. Is there any common issue on this 565 that i intend to buy ?
thanks in advance . -
Starlight, what Uncle Jesse is trying to say, is unless you plan on listening to a SINGLE SDA (mono), you're one amp channel short of a great listening experience.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Hi Russman,
Of course the 565 comes in a pair , please enlighten me if I can drive the
SDA SRS without the common ground issue , thanks . -
They don't have to come in pairs and you used a singular description in your comments. The English language is a finely honed tool and when used correctly is very helpful to all involved.
Anyway, there are two circumstances when you can use mono block amps with SDA SRS speakers. One is if your serial numbers are above 5001 on both speakers. If so, you can use the special AI-1 interconnect cable, which you'll have to make as it's no longer sold. The other is if you can tie the negative outputs of the amps together to create a common ground. You'll have to check with Adcom to see if that can be done with those amps. -
StarlightWk,
The GFA-565 monoblocks will work great with the SRS's. I have a pair of these amps as well as SRS's. You will need to do the following things:
1. Connect the negative binding post terminals of each amp together with some good quality wire.
2. Connect the chassis of each amp together with some good quality wire that is the same size gauge as the wire connecting the negative binding post terminals. The chassis screws make good connection points. A good idea is to solder each end of the wire to a thin metal washer that has a soldering tab.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Thanks DarqueKnight, will follow as per your instructions. Better go snap up the mono blocks b4 there are gone . Its hard to come by these mono blocks in by
area. Cheers ! -
Thanks to F1nut too.
What about me?
High five!Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Thanks Russ.
Last but not least RUSS the Man, Thanksssssssss
