I would like to put a built in fan in my HK7200
SOUNDMASTER5158
SOUNDMASTER5158 Posts: 13
edited May 2006 in DIY, Mods & Tweaks
I would like to put a built in fan kinda like a computer fan on the top of my unit right directly in the middle where I have room between the amplifiers.
What I would like to know is how can it be done and is their a way to plug or soder the wires too it.
Any info is greatly appreciated.
tyia
Eric
:cool: :DEric Eck
Clinton Township Mi 48036
Hitachi HDTV 72 inches by 16:9
Harmon Kardon AVR 7200
Harmon Kardon (2) PA 2000
Harmon Kardon (2) PA 4000
Polk Audio (4)RTI 150
Polk Audio (2) LSIC
Polk Audio (4) LSFX
Xbox
Xbox 360
Playstation 1
Playstation 2
Playstation PSP
:D :cool:
Post edited by SOUNDMASTER5158 on
  • danger boy
    danger boy Posts: 15,722
    edited May 2006
    why?
    unless it's overheating and shutting down into protect mode.. you dont need a fan.
    PolkFest 2012, who's going>?
  • SOUNDMASTER5158
    edited May 2006
    The reason why is becasue I want to keep it cooler and to make sure I do not start the overheating or protect mode. once the unit starts doing it no matter what you do it will keep doing it and besides have you seen my layout on the electronics I own it all gets very warm inside even though they all have about 12 inches of breathing room top to bottom and side to side. not only that plus my warrenty ran out 2 months ago and I do not want to have to spend $3000 again on a decent reciever.
    :cool: :DEric Eck
    Polk Audio (2) LSIC
    Polk Audio (4) LSFX
    Xbox
    Xbox 360
    Playstation 1
    Playstation 2
    Playstation PSP
    :D :cool:
    VR3 Posts: 28,151
    edited May 2006
    Get a different receiver.
    $3,000?
    Scratch get the receiver idea, get a preamp + amps.
    Or get a real receiver, from B&K or Rotel, etc.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2006
    Any ad-hoc wiring utilizing the existing equipment is not a good idea.
    If you seriously want some pre-built cooling solutions, Active Thermal, is one source for the gear. If you want to save some money, there are a number of DIY ideas for this application as well...just search the web.
  • Early B.
    Early B. Posts: 7,900
    edited May 2006
    I agree with danger boy -- forget about it.
    Generally, HK receivers run a bit hotter by design. Just make sure you give it adequate ventillation and you'll be OK.
    "God grooves with tubes."
  • SOUNDMASTER5158
    edited May 2006
    Thank you for the idea.
    Eric
    :cool: :DEric Eck
    Polk Audio (2) LSIC
    Polk Audio (4) LSFX
    Xbox
    Xbox 360
    Playstation 1
    Playstation 2
    Playstation PSP
    :D :cool:
