I would like to put a built in fan in my HK7200
SOUNDMASTER5158
I would like to put a built in fan kinda like a computer fan on the top of my unit right directly in the middle where I have room between the amplifiers.
What I would like to know is how can it be done and is their a way to plug or soder the wires too it.
Any info is greatly appreciated.
tyia
Eric
tyia
Eric
:cool:
Eric Eck
Clinton Township Mi 48036
Hitachi HDTV 72 inches by 16:9
Harmon Kardon AVR 7200
Harmon Kardon (2) PA 2000
Harmon Kardon (2) PA 4000
Polk Audio (4)RTI 150
Polk Audio (2) LSIC
Polk Audio (4) LSFX
Xbox
Xbox 360
Playstation 1
Playstation 2
Playstation PSP
:cool:
Polk Audio (2) LSIC
Polk Audio (4) LSFX
Xbox
Xbox 360
Playstation 1
Playstation 2
Playstation PSP
Post edited by SOUNDMASTER5158 on
why?
unless it's overheating and shutting down into protect mode.. you dont need a fan.PolkFest 2012, who's going>?
The reason why is becasue I want to keep it cooler and to make sure I do not start the overheating or protect mode. once the unit starts doing it no matter what you do it will keep doing it and besides have you seen my layout on the electronics I own it all gets very warm inside even though they all have about 12 inches of breathing room top to bottom and side to side. not only that plus my warrenty ran out 2 months ago and I do not want to have to spend $3000 again on a decent reciever.:cool:
Eric Eck
Polk Audio (2) LSIC
Polk Audio (4) LSFX
Xbox
Xbox 360
Playstation 1
Playstation 2
Playstation PSP
:cool: -
Get a different receiver.
$3,000?
Scratch get the receiver idea, get a preamp + amps.
Or get a real receiver, from B&K or Rotel, etc.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Any ad-hoc wiring utilizing the existing equipment is not a good idea.
If you seriously want some pre-built cooling solutions, Active Thermal, is one source for the gear. If you want to save some money, there are a number of DIY ideas for this application as well...just search the web.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I agree with danger boy -- forget about it.
Generally, HK receivers run a bit hotter by design. Just make sure you give it adequate ventillation and you'll be OK.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thank you for the idea.dorokusai wrote:Any ad-hoc wiring utilizing the existing equipment is not a good idea.
Eric:cool:
Eric Eck
Polk Audio (2) LSIC
Polk Audio (4) LSFX
Xbox
Xbox 360
Playstation 1
Playstation 2
Playstation PSP
:cool:
