Can I Use A Sub Cable To........
Dr. SpecDr. Spec Posts: 3,780
edited September 2002 in Electronics
Can I use a spare Monster subwoofer cable to connect between the rear center pre-out on my HT receiver and the Harman/Kardon amp I will be using to power the rear center?
I guess I don't know enough about the sub cable design - is it designed to accept a full range signal or just bass signals?
If the general consensus is NAY on the sub cable, what type of interconnect would be a better choice?
Thanks for the help...........
Doc
Ed Mullen ([email protected])
SVS
Post edited by Dr. Spec on
  • Frank ZFrank Z Polk-a-dweeb Posts: 5,967
    Cable is cable. I have never seen or heard of a cable(only) that has the ability to pass a limited freq. range. Any reason why you don't use a good quality analog rca cable?
  • Ron-PRon-P Spaceman Spiff Posts: 8,511
    What Frank said. My guess, marketing ploy by Monster. Use it. Hey, if all you hear is bass, then.....:)
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • MxStYlEpOlKmAnMxStYlEpOlKmAn Posts: 2,116
    considering u can hook a sub to a receiv. with rca plugs...i dont see y
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • RuSsMaNRuSsMaN Posts: 17,995
    G'head, use it.
  • nascarmannnascarmann Posts: 1,464
    Yes, use it. I'm using a AR video cable (you know, the yellow one) from the cable box digital audio out to the receivers digital in and it sound great. Tried a Monster digital coax and couldn't tell the difference :rolleyes: Also have my sub running of a video coax, the same yellow thingie and it pounds away.....
    But hey....if it make you feel better, go drop 150 bucks on a Transparent cable....
    Oh, the bottle has been to me, my closes friend, my worse enemy!
  • Dr. SpecDr. Spec Posts: 3,780
    Cool - thanks for the opinions. I figured I could use it, but I wanted to check first. I agree - never heard of a "low pass" RCA cable.
    The only reason I am not using "a good quality analog RCA cable" is because I don't have any! After the PC+ arrives tomorrow, I'll have this extra sub cable lying around and I figured I could use it for the rear center.
    Funny........my rear center (if I ever install it) will have by far the highest quality amplification of all my speakers.
    If I had pre-outs for all my speaks, the h/k 870 would be powering my mains in a heartbeat, especially for 2 channel listening. Maybe some day I'll go separates.........
    Thanks again!
    Doc
    SVS
Howdy, Stranger!
