Am I stupid or just curious?
Shizelbs wrote:So, am I stupid or just curious QUOTE]
Is there a third option? :eek:
OK, I choose "D"-Ignorance is strength - -
Edit-Sorry, my bad. All I meant was that they use diiferent tubes, one uses a rectifier tube, one uses sonicaps and other high quality parts and they seem to also be of different designs in general. The similarities are that they are priced similarly and use tubes. I'm not saying one is better than the other, because that's subjective . I prefer the 6DJ8 variants over the 12A*7 variants and I've owned pres that utilize both."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Apparently I am a total dumbass for trying to compare anything to the Dodd. :rolleyes:
The fact of the matter is that I know it is extremely possible to have warm, airy characteristics from a SS pre for a lot less money that even an entry level tube pre and you still get a remote.
WesLink: http://polkarmy.com/forums
Panasonic TH-42PHD8UK 42" HDTV | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Wyred 4 Sound STP/SE Pre | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Oh please, noone was attacking you personally or calling you a dumbass. Just pointing out that the two pres aren't really that similar, other than them being entry tubed pres.
Peace brotha:)"SOME PEOPLE CALL ME MAURICE,
I feel the 6DJ8/6922 family is more accurate and detailed than the 12A*7 family. But the *7's does have a warmer sound.
I have the Audcom AP-110 pre with 396/5760 tubes, with remote, and it sounds fantastic!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
ND13 wrote:Oh please, noone was attacking you personally or calling you a dumbass. Just pointing out that the two pres aren't really that similar, other than them being entry tubed pres.
Peace brotha:)
No problems, just that your side-by-side sure made it seem like the Dared and the Dodd were a lot closer than in the neighborhood, more like they were on the same street, hence my very mild interpolation to take your comparison in a slightly different direction. :cool: Then I get jumped on for it. If we were talking MLP vs. the DLC or the entry Dared, then sure, I'd be making a very large jump, but you said it yourself that they compared very favorably with each other.
Go figure...
Dared vs. Dodd (and sorta vs AA DLC)
Hey, ISIG, if it'll make you feel better, I'll be happy to consider you a dumb-****...More later,
Tour...
Vox Copuli
The dodd and dared are in the same league no matter who made them.. The dodd is made in the USA by hand and we love gary so it has an upper hand around here...otherwise they are comparable.. I have been wanting to try SS pre again as well.. i have tube pre and amp now and love it.. but want something different all the time.. Try SS again and be happy...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I-SIG wrote:No problems, just that your side-by-side sure made it seem like the Dared and the Dodd were a lot closer than in the neighborhood,
Wes
I've learned a little more about them since then. I wasn't jumping on ya, just disagreeing is all.
I still maintain that you can't go wrong with either choice. It will come down to which tube you like the sound of better and whether or not you need a remote.:)"SOME PEOPLE CALL ME MAURICE,
