Power shampoo recommendation
haimoc
I am building a 2-channel stereo system, and a power shampoo (or conditioner) is the last component. Any recommendation for one? Budget is about $400.00.
Thanks.
Thanks.
Post edited by haimoc on
PS Audio UPC-200Political Correctness'.........defined
President of Club Polk -
Triplite 2400 if you need under voltage protection, otherwise I concur with the UPC-200
Thanks... There are 3 offers on Audiogon... I'll look into this recommendation.
Panamax 5100EX.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
There are two types to look at. Some run the power through a transformer or autoformer (if undervoltage protected) and others are across the line which means the power is still connected directly but the protective and conditioning components are in parallel rather than in series with the line voltage. It's up to you to figure out which is optimum for what. Normally amplifiers like to be direct to the line (tightest voltage regulation) but most source components like to be transformer isolated. (hum issues if any).
madmax
PS: I'm a big Panamax fan too.Vinyl, the final frontier...
I was thinking to get Panamax 5300, but want to see more good choices before buying one.
Just looked at what I have! Change my previous recommendation to Panamax 5300EX! I have the previous model, the 5100. Works very nice for my 2 ch. rig.DKG999
Panamax is good, but Pantene is a much better conditioner. My hair is silky smooth...............HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
There are really only 2 I'd look at. The Blue Circle BC606 @ $299.99 or a Richard Gray unit for roughly $400 (under that used). I think most of the mainstream stuff (Monster and Panamax) is great for video but alter's the audio in perhaps a worse way.
Panamax!!2 Channel Rig
Source 1 - Apple TV
Source 2 - Parasound D3 Universal Player
Source 3 - Parasound Tuner T3
Pre-amp - Parasound HALO P3
Amplifier - Parasound HALO A21
Speakers - Martin Logan Vista
Power Conditioning - Panamax M5100-EX -
Wish I had the cash to buy it for myself, but there is a UPC-200 B-stock at PS Audio's web site for $349. It says there is a blemish on the bottom that you can't see when it's sitting on it's feet, so basically who cares! Full warranty...
http://psaudio.com/cart/BStock.aspSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
