Power shampoo recommendation
haimoc
haimoc Posts: 1,031
edited April 2006 in 2 Channel Audio
I am building a 2-channel stereo system, and a power shampoo (or conditioner) is the last component. Any recommendation for one? Budget is about $400.00.
Thanks.
Post edited by haimoc on
    F1nut Posts: 52,008
    edited April 2006
    PS Audio UPC-200
  • madmax
    madmax Posts: 12,434
    edited April 2006
    Triplite 2400 if you need under voltage protection, otherwise I concur with the UPC-200
    madmax
    Vinyl, the final frontier...
  • haimoc
    haimoc Posts: 1,031
    edited April 2006
    Thanks... There are 3 offers on Audiogon... I'll look into this recommendation.
  • dkg999
    dkg999 Posts: 5,647
    edited April 2006
    Panamax 5100EX.
    DKG999
  • madmax
    edited April 2006
    There are two types to look at. Some run the power through a transformer or autoformer (if undervoltage protected) and others are across the line which means the power is still connected directly but the protective and conditioning components are in parallel rather than in series with the line voltage. It's up to you to figure out which is optimum for what. Normally amplifiers like to be direct to the line (tightest voltage regulation) but most source components like to be transformer isolated. (hum issues if any).
    madmax
    PS: I'm a big Panamax fan too.
  • haimoc
    haimoc Posts: 1,031
    edited April 2006
    I was thinking to get Panamax 5300, but want to see more good choices before buying one.
  • dkg999
    dkg999 Posts: 5,647
    edited April 2006
    Just looked at what I have! Change my previous recommendation to Panamax 5300EX! I have the previous model, the 5100. Works very nice for my 2 ch. rig.
    DKG999
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited April 2006
    Panamax is good, but Pantene is a much better conditioner. My hair is silky smooth...............
  • LuSh
    LuSh Posts: 887
    edited April 2006
    There are really only 2 I'd look at. The Blue Circle BC606 @ $299.99 or a Richard Gray unit for roughly $400 (under that used). I think most of the mainstream stuff (Monster and Panamax) is great for video but alter's the audio in perhaps a worse way.
  • Beekyman
    Beekyman Posts: 150
    edited April 2006
    Panamax!!
    2 Channel Rig
    Source 1 - Apple TV
    Source 2 - Parasound D3 Universal Player
    Source 3 - Parasound Tuner T3
    Pre-amp - Parasound HALO P3
    Amplifier - Parasound HALO A21
    Speakers - Martin Logan Vista
    Power Conditioning - Panamax M5100-EX
  • tryrrthg
    tryrrthg Posts: 1,896
    edited April 2006
    Wish I had the cash to buy it for myself, but there is a UPC-200 B-stock at PS Audio's web site for $349. It says there is a blemish on the bottom that you can't see when it's sitting on it's feet, so basically who cares! Full warranty...
    http://psaudio.com/cart/BStock.asp
