Need help with a turntable/grounding issue..
aaharvel
Ok so I got the turntable, the separate phono pre-amp.
Everything's hooked up right with the receiver, except the music volume is low and i'm getting noticeable humming.
I assumed it's a grounding issue so i went to RatShack and bought some spades and a grounding wire. They don't have the wire and the guy said I could just use speaker wire. There's a grounding terminal on the back of the pre-amp and another one on the back of the turntable. Do I just connect one end of the speakerwire w/spade on the ground terminal of the turntable and the other one on the pre-amp?
H/K Signature 2.1+235
Jungson MagicBoat II
Revel Performa M-20
Velodyne cht-10 sub
Rega P1 Turntable
"People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
Revel Performa M-20
Velodyne cht-10 sub
Rega P1 Turntable
Post edited by aaharvel on
If you want something cleaner, I ordered some replacement gound wires for my 1200's (the spades came off and they were getting frayed) and they accidentally sent me 3 instead of 2. PM me if you want the spare.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Well, what did you do? Connect the dots?aaharvel wrote:nevermind. that was an easy one to fix.More later,
Tour...
Vox Copuli
