For 49 cents - can't go wrong but where ??
begbie
begbie Posts: 630
At www.audiorevolution.com , they recommend a 49 cent ground floater to kill ac hum. Worth a try but the local Home Depot (Canada) doesn't carry this 49 cent piece ?! Anyone ever try this and how well has it worked? Anywhere else I can find this piece?? Or am I just in the wrong department at Homedepot?:confused:
Here's the desciption from their site (under rewards section)
"Home depot brand Ground Floater-49 cents
AC ground hum is an evil **** that needs to be attacked with reckless abandon. Before you clip the third prong from the AC power plug on the offending component – try a 49 cent ground floater from Home Depot. Any good installer will tell you, they can be a life saver and a hum killer."
Polk Rt800i -Fronts
Polk cs400i -Center
Polk fx500i -side surrounds
Polk rc60i -rear surrounds
Onkyo TX-NR 1009 (9.2) receiver
Velodyne cht12
Polk psw111
Post edited by begbie on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2003
    Cheater Plug, Rat shack has em'.
  • begbie
    begbie Posts: 630
    edited January 2003
    Thanks Russman ! I'll try my luck there ! :)
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
  • pare
    pare Posts: 11
    edited April 2006
    I just bought RM6800 and the subwoofer makes a very low hum. It hums just with the power chord connected.
    I suspect it's from transformer. The sub plug is two pin and I have the 3 pin socket. would this cheater plug help and is it still available (replying to a 2002 thread).
  • McLoki
    McLoki Posts: 5,231
    edited April 2006
    Nope, wont help you. Sorry. What the cheater plug does it remove the ground plug from a 3 prong wire and make it act like a 2 prong plug. (without cutting the end off the plug and just putting a 2 prong plug on there)
    Since you are starting with a 2 prong plug, your problem lies elsewhere....
    Good luck.
    Michael
  • polrbehr
    polrbehr Posts: 2,865
    edited April 2006
    Don't cut off third prong... it's there for a reason. It grounds the external chassis of equipment so in the event the hot wire comes in contact with it the circuit breaker will (should) trip. Removing the ground prong or using a cheater will not prevent what is in all likelihood a 60 cycle A/C hum, nor will it prevent you from getting jolted should that situation occur. Michael (above) is correct. I would try a decent line conditioner or UPS, as most of them rectify A/C to D/C and back again.
  • unc2701
    unc2701 Posts: 3,587
    edited April 2006
    Cheater plugs aren't terribly dangerous for amplifiers... and many amps have a ground lift switch that does the same thing. It's not the best solution, but it works. A better (and safe) fix would be to replace the outlet with a GFCI and only hook up the hot and neutral lines. This meets code and will effectively be the same as using the cheater plug.
    Backburner:Krell KAV-300i
  • polrbehr
    edited April 2006
    If you're going to replace the outlet anyway without hooking up a ground wire, save yourself some money and just buy a duplex receptacle. Hooking up
    a Ground Fault Circuit Interrupter without a ground isn't going to accomplish much. I was addressing the (potential) danger of removing the ground prong in general, not specifcally for amplifiers, which I agree don't draw much current.
  • unc2701
    edited April 2006
    The potential danger of removing a ground plug can be avoided by using a ground fault receptacle as I described. Any voltage on the chassis would trip the outlet. This is also a way to add three prong outlets to older wiring without the ground. Anything downstream from the GFCI is protected.
  • polrbehr
    edited April 2006
    I couldn't get a GFCI to trip without intentionally creating a short circuit, but it will, as you describe, protect whatever is plugged in to it whether the ground is connected or not, so you're suggestion is actually a great ($$$) alternative to a line conditioner or UPS for amp/equipment protection, as well
    as being useful for older wiring. I would just add that you must connect any wires downstream to the "load" terminals on the GFCI, for anyone interested.
